First I have to get the machine at home and try to repair it. I have not seen it close up yet, these pictures were taken by my son. Does it use a router to carve out things? Which means you have to select and attach various bits on it? Or does it use laser? My son told me that their new CNC machine at school uses laser. If this machine uses a router bit, is it strong enough to carve PCB and/or thin aluminium panel? Or is it only good for softer materials like wood and plastics?
Based on the last two photos, it's using a spindle (router). So definitely uses bits. It should be able to do PCB and soft metals such as aluminum or copper. Just be mindful of the feed rate (speed the spindle is pushed/pulled across the material surface), or you'll run into problems, including broken bits. Hopefully
robrentz will chime in on this part. If not, a search or two should turn up this sort of information.
There will be settings for feed rate, depth, tool size, ..., in the CAD software. And as it's a Roland, you should be able to get it to work with existing drivers.
