Author Topic: Code Poetry  (Read 863 times)
Offline Omega GloryTopic starter
    • Ezra's Robots
Code Poetry
« on: April 18, 2024, 03:22:49 am »
Anybody here every try writing code poetry? Here's an attempt in Python. This will run (assuming "ant.py" exists), but doesn't do anything. The best code poems actually have some kind of neat side effect.
« Last Edit: April 18, 2024, 02:29:51 pm by Omega Glory »
Offline EPAIII
Re: Code Poetry
« Reply #1 on: April 18, 2024, 05:52:41 am »
Some people have
ENTIRELY TOO MUCH
time on their hands.
(It doesn't rhyme, but it has a sort of meter.)
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
The following users thanked this post: Omega Glory
Online SiliconWizard
Offline IanB
Re: Code Poetry
« Reply #3 on: April 18, 2024, 07:06:17 am »
    • Ezra's Robots
Re: Code Poetry
« Reply #4 on: April 18, 2024, 01:57:52 pm »
@EPAIII
Yeah, it doesn't rhyme, but I was trying to limit myself to keywords as much as possible, which makes it hard. The
open("you","r") was fun because the "r" actually does something here (tries to open the file "you" in read mode). And the fact that it comes between the a
try: and
finally: means if the file doesn't exist, the exception will be caught. Though to be fair, the underscore will evaluate to False which may prevent the open from running due to "short circuit" evaluation of the logical and. Ah, and the first if statement will evaluate to False anyway.
 @SiliconWizard
Shakespeare is great, hahaha. Have you seen Chef? https://esolangs.org/wiki/Chef (nice example), https://www.dangermouse.net/esoteric/chef.html (syntax)
« Last Edit: April 18, 2024, 02:28:50 pm by Omega Glory »
Re: Code Poetry
« Reply #5 on: April 18, 2024, 08:06:20 pm »
@SiliconWizard
Yes, I had seen Chef. In the same vein, there is also Rockstar: https://codewithrockstar.com/
Offline paulca
Re: Code Poetry
« Reply #6 on: April 21, 2024, 07:14:10 pm »
while( you.love(me.love(you)) ) {}
