I am a hobbyist with a little electronic knowledge, and have got an SMD diode that is burnt out as per the picture.
The diode marking is a white A (which matches a BAT14-098 Schottky diode) I did try asking this on a different forum, however it didn't return any real results.
As per the 2nd photo you can see that it is just mainly used for protecting the 5v throttle supply for an electronic scooter
I forgot to add.. what replacement diode could I replace this with please. Obviously, I need to find out what caused the diode to burn but could be the fact its an incorrectly used diode in the first place since this board does not require 12GHz frequency requirements.
Note also: the other side (5v brake supply) also has a diode with same marking, however this also has a trace that goes to a DK9t marking 5pin component pin1
