Author Topic: Component identification - help  (Read 235 times)
Offline k.valentino
« on: June 14, 2021, 11:51:33 pm »
Hi, need help with identification one transistor  |O (or maybe voltage regulator). I need to replace it.
MMBT2907A ???
The transistor is burned and is from car's gas analyzer machine that have problem with the display.
Offline cortex_m0
Re: Component identification - help
« Reply #1 on: June 15, 2021, 01:43:35 am »
MMBT2907A makes sense, if the theory of the circuit is to vary the LM324 negative supply rail with changes in temperature.
I'm not sure why you'd do that, but it's a circuit I could imagine working.
The following users thanked this post: k.valentino
Offline SpecialK
« Reply #2 on: June 15, 2021, 03:23:17 am »
Is it really burned?
The SMD code app on my phone suggests 2.5V LDO.
I guess I wouldn't mind a look at the complete board.
Offline k.valentino
« Reply #3 on: June 15, 2021, 10:29:59 am »
Thanks for the answers! Yes, the transistor is burned (have fuga).
Offline bob91343
« Reply #4 on: June 15, 2021, 05:38:33 pm »
I would guess the equivalent would be 2N2907A which is in TO-18 package.
