Hi thanks in advance for you help,
I have a component (I believe it is a thermistor. Can you confirm) de soldered from a device. Could somebody help me identify the type of thermistor and suggest a method/procedure to identify the resistance ?
Also on close examination I found that the there are two thermistor connected in series with each other. Could somebody guide me to find the values ?
I am enclosing the picture . On one of the thermistor it is written as "151" and on other as "52 56"
Thanks again
