Author Topic: Component Identification help  (Read 511 times)
Offline andrevamp9297Topic starter
« on: October 29, 2020, 03:13:54 pm »
Hi thanks in advance for you help,
I have a component (I believe it is a thermistor. Can you confirm) de soldered from a device. Could somebody help me identify the type of thermistor and suggest a method/procedure to identify the resistance ?
Also on close examination I found that the there are two thermistor connected in series with each other. Could somebody guide me to find the values ?
I am enclosing the picture . On one of the thermistor it is written as "151" and on other as "52 56"
Thanks again
Offline Jetecnet
Re: Component Identification help
« Reply #1 on: October 30, 2020, 02:20:43 pm »
151 in a sot23 is likely an NXP KTY82/151 Silicon temp sensor
