You are too kind, thank you. Didn't translate it yesterday, because the datasheet mentions uA725, so downloaded the datasheet for uA725 and read that one instead. However, you made me curious, and gave translate.google.com a try this morning. Attached is the En pdf returned. No idea how accurate the translation is. Did Google translated it good enough?
Searched a little more today about uA725, and found out (at page 59 of 970 in
http://www.miedema.dyndns.org/co/2018/Op_Amp_Applications_Handbook-Walt-Jung_2005.pdf)
In 1969 Marv Rudin and Garth Wilson formed Precision Monolithics Incorporated
(PMI), a brand new company with a charter of precision linear ICs. PMI introduced their
counter to the 108A, the OP08, in 1976. This wasn't simply a second source to the 108A,
but a revised and upgraded design by George Erdi and Larry Farnsley. Erdi was known as
the father of the Fairchild μA725 (and the SSS725, at PMI). Erdi came to PMI in 1969,
from Fairchild, where he had already established some key op amp design concepts (see
narrative on 725 to OP07).
In the same pdf, it's an entire chapter describing the internals of the uA725 opamp, wow!
"Precision Bipolar IC Op Amps— μA725 to the OP07 families" starting at page 61 of 970.
The question now is what to build with low noise, low drift, precision opamps like
uA725?
