Author Topic: Component tester, TC T7-H or PEAK Atlas DCA75 pro?  (Read 1016 times)
Offline xzswq21Topic starter
« on: June 09, 2021, 05:46:34 pm »
I want to buy a component tester, but I'm skeptical which one I should buy, a Chinese TC T7-H or a British DCA75 pro?
Thanks
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: Component tester, TC T7-H or PEAK Atlas DCA75 pro?
« Reply #1 on: June 10, 2021, 01:21:32 am »
IMO it depends for what you want to do. The major advantage of the DCA75 is indeed the interface with the PC. If you are interested in just a quick component checker, then the Chinese tester is a much better bang for the buck.
At first glance the DCA75 tests a wider variety of devices, but the Chinese has a higher test voltage and current, which skews the tip in its favour.
Offline SteveyG
  • Soldering Equipment Guru
« Reply #2 on: June 11, 2021, 07:10:18 pm »
The DCA75 is pretty solid, I've not had any battery issues either - the last time I replaced the batteries was about 5 years ago!
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
