Have a look at XMOS
Will have a look at that, thanks
Why would you want them as big as 0805?
Plenty of cheap smaller arrays.
Just because its quick/easy to hand assemble 0805.
The 0604 arrays are still quite expensive and usually use a custom footprint which doesnt match the individual components in a row.
Don't see why it would need to be single chip - I suspect the main issue is power due to the processing needed.
Broadcast formats are targetted at low cost decode and good compression without worrying about latency.
For FPV you could probably design a different encoding scheme that would be a much better fit - e.g. low latency, optimised for low encode effort and a graceful degrade in resolution as error level increases
Yeah, i wasn't being too serious.
In practice yeah, it probably needs separate HDMI decode chip, video encoder, transport encoder, and RF amp chip
Yeah, a encoding scheme with feedback would be best. So as you fly out of range it automatically dials back the bitrate to keep an image.
However the data encoding format should really be OFDM to avoid multipath, like dvb.
