You COULD buy discrete transistors. You STILL can! Integrated circuits didn't even exist back then. Saying that because transistors on today's integrated circuits have different characteristics than the discrete parts they evolved from is only a characteristic of the scale and physics. That you even go so far as to say such a discrete part exists (even if utterly rare) disproves your own statement. Limited availability of one particular variant is irrelevant to the fact that it actually exists!
My POINT is arguing for a proper evolution of the technology from the bottom up, so learning, experimentation, innovation, and prototyping are possible. Your argument completely MISSED the point that transistors DID exist as discrete devices first. That integrated devices came later is great, but it also did not eliminate the discrete transistor.
I'm sorry, but I can buy a damn transistor. That it's not commonly available in every conceivable variant under the sun does not eliminate the fact that I can buy a damn transistor!
With memristors... there are NO VARIANTS available...
That would be why I'm gonna go build my own memristors, with blackjack and hookers. In fact, forget the blackjack and hookers!
So what? It's a novelty component. If you want to play with one, slap together an integrator with an analog multiplier and make one. It's not a particularly useful component (despite academics cheering about theory and symmetry), and physical (rather than synthesized) examples, such as used in the memory, probably have awful properties (consistency, accuracy, drift, tempco), barely good enough for storing data.
That said, I should think something like an MOV or thermistor could be constructed to exhibit the same behavior in bulk, so you could have a memristor with real watts capacity and hundreds to k's of resistance range.
Transistors were once an over expensive, terribly fragile novelty component, in an era where valves were the defacto standard technology. People understood they could mark an improvement and a fundamental shrinking of technology, with reduced power needs than valves... but yes, even in the very early days, transistor were once novelty components. They VERY quickly found their niche with the transistor radio, and then made their way into computing applications, other audio amplification devices, operational amplifiers, etc. Sound familiar? ICs were once quite frivolously novel. Chips were out for a WHILE before they were universally adopted. Between the US military buying every last one they could find, and their expense, people saw no need to integrate what could be made cheaper with a few transistors. Eventually, the market caught up, and that changed.
I hope that changes with memristors sooner than later...
My interest has always been in the neural / synaptic potential of memristors. It's a field with little research, and it pertains to my own interests. The fact that people dismiss memristors so easily is exactly WHY it's so necessary to be able to experiment with the real deal. The experimenters, the prototypers, the curious! Those are the ones who will come up with the idea, or stumble on some unexpected configuration that the next person misses! not everyone can see passed the everyday.
It just feels like wasted potential, mixed with a bit of hypocrisy. HP says they want to usher a new revolution with a "fourth fundamental circuit element", but they expect that revolution to be on their shoulders, and that everyone must follow their path. No thanks. How bout they give me a component that
I can be creative with! Revolutionary memory is great! FPGAs are great as well, but give us not just an FPGA that is enhanced through the integration of memristors to make it more dense, but give us an... I dunno, let's call it an FCMA - a Field Configurable Memristor Array, that doesn't just perform digital logic using memristors to achieve better density, but actually uses something like CMOS analog switches (as in similar to a CD4051, for example) to create a truly user accessible memristor array that an be reconfigured into custom analog circuits. Even having a small 16 pin chip containing 8 individual memristors would be great! Maybe we could have a 20 pin IC that has 16 memristor interconnect lines (connecting to 8 memristors), but features CMOS analog switches internally to switch banks, and has 2 wires to either select from a multitude of banks (each bank being 8 memristors) via serial commands, or has 4 banks selected by a 2 bit code. A 24 pin IC could easily contain 64 banks of 8 memristors (6 bit binary bank selection). 32 or 512 individual memristors might not sound like much at all, but consider that in the hands of a resourceful experimenter, they would be IDEAL learning tools, and I know I could personally use such a device myself. Another option would be small crossbar latch style chips. An 18 pin chip could easily contain 16 rows and a pair of columns. a 20 pin chip could do a 16x4 crossbar latch, as a 24 pin chip would enable a 16x8 configuration. An additional option would be to have disable lines that isolate a column's memristors from adjacent columns (using analog CMOS switches), to allow hard setting the memristor states via isolation, or alternately, enabling or disabling the memristor connection at that point ( a little CMOS logic plus an additional memristor to store the state of that matrix point). I'm rambling on about a potential entire LINE of memristor based small scale integrated chips. Kinda pointless at this point. Even just the FPGA style chip with accessibility to analog compatible I/O fed directly to the memristors would be AMAZING!
I just have issue with the fact that HP COULD create such devices, and sell them to the world so they could learn the new technology and become even more excited at the potential... But they instead just keep all of it internal, and promise memories. I can only store data with a memory. I can't really experiment with neural synaptic devices, or other people experiment with the non linear analog aspects of memristors... Not unless someone creates such parts.
The point of my entire argument, is I believe HP has completely missed the point and forgotten that they can develop all they want internally, but if they want the technology to take off, the WORLD needs to adopt it, and that means teaching the technology by doing... Letting the world get their hands dirty with memristors!
I wouldn't BE here on this blog's forum if I didn't
want to get my hands dirty!
If I sound agitated, it's cause I'm tired of rhetoric, and i've been hearing it for more than half a decade! What can I say? I understand that HP wants to pay the bills and bring home a new Aston Martin for shareholder's A through V (W to Y each want a Ferrari, and Z wants a Lambo! LOL)
Still, there really isn't any reason at all that a small team could devolop their in house development silicon into real world applicable devices, such as small scale memristor arrays. Such devices would NOT compete with their memory product line, and would not threaten their internal development! Releasing small scale memristor devices would only educate the world of the potential of their new technology! I just have not seen
any indication that they are
actually doing anything of the sort!
HP is focusing on the evolution of existing concepts with new technology. They want to make what exists faster, denser, more unified... More evolved, but they are not thinking outside the box. They don't have that spark of innovation that asks, what can we do with this that hasn't been done EVER before! They just ask how we can make a shit ton of cash making mundane, but far superior memory.
