Telecoms will use 2 fibres, as the optical splitters required to make a bidirectional link on a single fibre are going to be quite expensive, and a hard to align item with a high insertion loss. Multiple fibres in a single jacket are cheap, reliable and have built in redundancy as well in case you have a snapped strand along the cable run.
Short distance links you can use a LED each end and run one as a photodiode and the other as emitter, and arrange the protocol so as to do the half duplex required.
A 74HC4066 that doesn't have a retarded pinout - place all the enable pins next to each other please!
And make the input thresholds 1V regardless of supply.
The 74HCT4066 is not close enough?
Well, it matters when you don't run Windows (or Linux). It would just be convenient for me personally not having to mess around with a platform I don't otherwise use, and hopefully the community could at least manage some minor tweaks to the tools too.
i take it you are on a MAC then ? sorry bub. wrong computing platform.
All the FPGa tools are winodws / linux. Even Apple designs their boards using windows.
They are not discussing discrete memristors, fixed configuration multi memristor integrated devices,
-snip-
Imagine a world where all the resistors, or all the capacitors, or all the inductors were taken away, and you could only get such fundamental parts as integrated into premanufactured integrated components. The concept is absurd,
and what exactly would you do with a single memristor ? Besides do you have any idea about what is needed to read and write it ? the currents and voltages you are dealing with are extremely small. reading the state is destructive : state needs to be written back. it is an impractical device off-chip. i doubt that hwat you have constructed is the same as what hp is building on-chip.
as for a world without passives... coming sooner than you think. severalcompanies already offer integrated passives as in 'a single package containing all r and c and l required'. these are used for further miniaturisation and space saving. tablets and smartphones already use these.
explain a bit more why you need open source pmos ? that doesnt make sense to me..
Ok strictly speaking, high-side outputs.
mc33880
Way more than a simple source driver, lots of pins, expensive
VNI8200
36 pins for 8 channels , expensive
UCN5891
UCN5890
discontinued, unavailable
-snip-
Presumably operation would be scaled up with larger devices to provide lower noise and larger signal-to-noise ratios. I would use them for low drift or non-volatile integration.
I have to point out that this function does occasionally show up in part failures where a resistance element fails as a mechanical junction and the resistance very roughly varies by the integration of the current through it.
It also has a 'hilarious' bug, where, at elevated (but still well within rated) temperature, commands from the SPI bus get acknowledged and can be read back, but don't get passed to the output drivers until the temperature drops, when they suddenly change to what they should have been.
Thanks, ST. As ever, designing in one of your parts turns out to be a mistake. (I'll check the actual part number tomorrow. It was, I think, the automotive rated version of that chip).
Edit: L9733XP is the (very similar) part with the mentioned bug. Grr.
A component I would love to see, is an op-amp, in a triangle shaped package, with the output pin on the point of the triangle, the inputs on the opposite side, and the power supply pins coming out of the other two sides.
That would be fantastic for prototyping stuff. I've wanted one like that for years
A triangle wouldn't fit on a breadboard very well though. They could be marked with the pinout on the DIP, at least -- or something like that. But, who would ever want to do that...
1. A shift register like a 595 that can do 1, 0, and Z on each pin, not just Z on all pins or none.
2. A cheap TRNG chip. Measuring a transistor in reverse mode seems convoluted and according to some is really not that random.
3. A voltage regulator in TO-220 or similar that can give -27v from 3.3v for LCD contrast without needing 10+ external components.
A mid-range microcontroller with a buttload of RAM (>64K) but without the cost of a ton of expensive flash
I have also thought for a long time that 256k RAM and 8k flash makes more sense than the other way around. A few k is enough for a bootloader to load code from an SD card or EEPROM to run everything from RAM to get around flash wait states. FRAM is a neat idea too but the MSP430s TI is making with it now top out at 8MHz.
Look at SPI GPIOs -- you're probably doing something like SPI to drive it, already. If it needs to be chainable, not sure.
That would be fantastic for prototyping stuff. I've wanted one like that for years .
I think a 3D printer and the application of some ingenuity could make that a reality fairly easily.
Except for the 23 chips which run at 16MHz, and the 10 which run at 24MHz..
Button switch signal conditioner for PIC/other embedded.
-8 channel in 1 IC.
-opto isolator per input.
-5V/12V on open contacts for light in the button.
-RC or other filtering, debounce, limiting the signal to 5? Hz.
-Schmitt trigger with 10%/90% for eliminating ingress.
-Output buffer capable of lighting a led, relay and uC.
-configurator pins for settings of filter, invertor, trigger,...
No rocket science, just an all-in-one for (long distance) buttons in your home, you robot, you machine.
Cut out some triangle shaped perf-board with those solder pads on the bottom, solder your favorite op amp in the middle and fashion some stick pins off the bottom add some periph parts, power and enjoy. Whooo Hoo!
+1,
Except it's not Whoo Hoo, it's Bob's your Uncle on this site.
All chips shall have programmable multiplexers allowing to exchange any pin position. Except power rails. They need to be on adjacent pins.
