Interesting that yours is mains powered. The ones used here are all powered by the imbalance current.Older ones ( late 1960's to early 1970's) used a BRY39 GCS thyristor to drive the trip relay, while the later ones up to the current generation use a simple biased coi to operate the trip mechanism, the trip drive energy being stored in a spring. They will operate with overvoltage, undervoltage and even with a broken connection to neutral on the supply side. There were a small range that had overvoltage and phase reversal protection, which used a 275V varistor on the line side and a 100v varistor on the neutral side, with the common along with the test resistor being connected to an earthing wire. There was also a range of prepayment meters which used the basic trip mechanism as a disconnector for the power, and they were quite common though they had a flaw in that you dould disable the trip by putting a needle into the unit through the plastic label they placed over the hole where the test switch was. Later on they put a plate there to block this hack. Newer meters also have back end checks as the payment is linked to the meter number, the old ones were a prepaid number that worked on any meter.
