General => General Technical Chat => Topic started by: TheAmmoniacal on April 28, 2016, 07:14:11 pm
Title: Computer Problems, need some help
Post by: TheAmmoniacal on April 28, 2016, 07:14:11 pm
Other forums dedicated to computer hardware have been less than helpful, so I'll give this place a try.
My computer is having (apparently) random and very intermittent freezes/crashes
Sometimes it freezes with a buzzing noise like this: https://youtu.be/KmJFVgOg34E?t=1s -- other times is freezes without any noise. This happens 2-3 times a week, and appears to be unrelated to anything I am doing. It doesn't happen any more frequently if I stress test my hardware, but it does appear to happen less frequently when I'm running Ubuntu (once a week). I'm currently on Windows 10 Insider Preview (the issues is not related to any particular build of Windows 10, been more or less the same on all).
I'm completely lost here, where do I start diagnosing this? Help/advice are very much appreciated, I'll run whatever tests seems reasonable.
The PC I had previously had major EMI issues, it would freeze up similarly (but without noise, ever) every time I put my mobile phone close to the motherboard (ASUS Maximus VII Impact), or if the phone was ~1 meter away from the PC during a call. Could it be something this obscure, again?
Hardware
Title: Re: Computer Problems, need some help
Post by: PA0PBZ on April 28, 2016, 07:20:37 pm
Where is the sound coming from?
(And why is the program in Dutch?  ::) )
Post by: TheAmmoniacal on April 28, 2016, 07:22:01 pm
That's just a random video I took off youtube, not mine! The sound is coming from the speakers (headphones), i.e. out of the on board audio card.
Post by: SeanB on April 28, 2016, 07:22:58 pm
First, have you taken it apart and checked all connectors for power and data, and applied any firmware updates? If so run Memtest and leave it to run for at least a day so there are no RAM issues, and then if no issues try turning down processor speed and memory timing to a more conservative setting,  and check the power rails for ripple.
Post by: PA0PBZ on April 28, 2016, 07:28:48 pm
Make sure that the system is not overheating, so take it apart and remove the dust form the CPU and GPU heat sink.
Also get the latest driver for the GPU.
Post by: continuo on April 28, 2016, 07:28:52 pm
Your GFX card seems to be some factory overclocked GTX 970. Try to set its clock rate to nVidia default level, there have been many reports of such overclocked cards got unstable after some amount of time.
Post by: TheAmmoniacal on April 28, 2016, 07:31:18 pm
Fist, have you taken it apart and checked all connectors for power and data, and applied any firmware updates? If so run Memtest and leave it to run for at least a day so there are no RAM issues, and then if no issues try turning down processor speed and memory timing to a more conservative setting,  and check the power rails for ripple.
I have taken the PC apart a few times for cleaning/sorting and installing new hardware, still hasn't made any difference to this issue. Only installed firmware updates for my SSD, afaik. The GPU and CPU both operate well within safe temperature range, the CPU don't pass 60 C on any single core even on full load (Noctua NH-D9L). The GPU to hover around 70 C when loaded.
I will run memtest overnight.
Post by: German_EE on April 28, 2016, 08:08:10 pm
Please check the 12 volt, 5 volt and 3.3volt power supply lines and make sure that the voltage is as close as possible to the correct amount. If they look OK then leave the meter on one of the lines and see if it alters during a crash.
If you have one an oscilloscope is a much better way to check the power supply lines as you can check for noise.
Post by: nctnico on April 28, 2016, 08:16:22 pm
Is it connected to a properly grounded outlet? Any ESD discharge sources?
Post by: Halcyon on April 29, 2016, 12:21:32 am
My machine at work does exactly the same thing, although it's an Acer and an absolute bucket of crap so I expect no less.
I think your motherboard might just be cheap and nasty. I'm generally not a huge fan of "consumer" motherboards, the closest I'd recommend would be Intel. Your previous ASUS board is a prime example of something that isn't designed properly. The last time I came across a machine that couldn't handle EMI was an old laptop which would lock up every time you hit the PTT talk button on an AM CB radio.
Post by: nogood on April 29, 2016, 11:11:06 am
The buzzing sound just tells you that basically everything software just crashed. IIRC this sound ist just the soundcard reading the same samples over and over again, because there is no sound driver to load anything else in there...
I had this, when my PSU would fold back the voltage to save itself, then of course immediately returning it, thus leading to me having a frozen picture and buzzing.
Post by: Stonent on April 30, 2016, 12:11:55 am
My thoughts are overheating of something.
Post by: ade on April 30, 2016, 12:25:39 am
I'd also suspect improper grounding.  The buzzing sound is likely from the 50 Hz mains cycle.
Check the outlets, PSU, chassis for proper grounding and that no cables / mobo connections are getting shorted.
Post by: amspire on April 30, 2016, 01:06:58 am
When I have had computers freezing, the most likely culprit is usually the power supply. I know the one you have a good quality and powerful one, but it is the first thing I would try and swap out. In one case, I had 8 PCs I was building with a reasonable quality ($100) 600W PSU. These only had a mid-range graphics card and no overclocking. Every PC was freezing randomly. I was able to swap the PSUs for a different 550W model from the same manufacturer and the freezes were gone. Sometimes for some unknown reason, a certain model power supply doesn't work well with a certain model motherboard. There will always be a technical reason, but I have never taken the time to debug it.
If you can get your hands on a 600W or higher PSU, even if it is a much lower quality one then the current PSU, try it. With power supplies, if it is a good brand name, then you can expect it will supply the rated power. Without looking up the specs, I would expect your system is still under 600W. This is not necessarily a permanent fix - this is to see if your PSU is the problem.
A second common problem is the RAM. Some motherboards just do not handle a full complement of large RAM well. I have two identical motherboards here at home - one can handle four slots easily, and the other can only handle two slots of large RAM reliably - freezes with all 4 slots loaded. That is an easy one to test - just reduce ram to 16G. If it still freezes, take out the 16G and put the other 16G in.
If the CPU has not had the thermal compound applied well, it can be worth removing the heatsink, cleaning the old compound off, adding a small amount of new compound. I have come across PCs that were assembled without any thermal compound, but if the temperatures are OK, this is not my first guess.
It can always be the graphics card, and the only thing you can do there is to plug in another card (even if it is a cheap $30 one) and see if the freezing stops. It is not a very conclusive test, but if the freezing still happens with a low powered GPU, then at least you know the problem is not the GPU and is not a power supply high load problem.
The noise is rectified mains noise getting though to the motherboard. It is the sound of 100/120Hz plus lots of harmonics. It can be an earthing problem as suggested, or a fault in the PSU.
Disconnect any external USB devices, such as printers, that have their own power supply. Powered speakers. Ethernet connections wouldn't be the problem. The monitor could be - try replacing it temporarily.
Post by: AntiProtonBoy on April 30, 2016, 02:15:15 am
You might also want to get the latest chipset drivers from the motherboard manufacturer.
Post by: Brumby on April 30, 2016, 03:25:07 am
I don't believe that would be the case.  If it were, the OP would be complaining about the buzzing being there ALL the time.
Post by: ade on April 30, 2016, 05:02:18 am
Not necessarily the case.  The obvious one is if the grounding issue is due to a intermittent connection.
A more common symptom is if the computer sometimes freezes or make noises when there's a second path to ground.   E.g., when the case is touched, when devices are being plugged in (e.g., USB, has a GND connection), etc.
That the mobile phone caused previous problems with freezing is also suggestive of poor grounding.
OP: does the computer freeze when you're actively working on something, or only when it's idle for a bit?
Post by: TheAmmoniacal on April 30, 2016, 05:19:07 am
It has only happened once that the PC froze up while I was not using it (waking up one morning finding it unresponsive).
memtest86+ passed, no errors.
Can't find much useful information on downclocking the GPU, ought I not also lower the voltage? To what?
I wouldn't know how to trace down grounding problems. But I could provide another potential key to the puzzle, if the metal shroud of my HDMI connector (hooked up to the monitor) touches my PC chassis that can cause it to freeze up instantly.
Post by: amspire on April 30, 2016, 05:34:22 am
That sounds really bad. Have you checked if both PC case and the monitor are connected to earth at all? You could be talking about something as simple as a power cable with a broken wire or a bad power socket wiring.
Have you checked the potential between the PC chassis and the shroud on the HDMI with a multimeter on both DC and AC volts?
Post by: nogood on May 01, 2016, 07:34:25 am
I dont think the buzzing comes from the mains, but maybe you can upload a sample if the computer crashes in the near future. that sounds exactly like a stuck soundcard buffer.
About freezing up when touching the chassis with connectors:
I do also have that problem, everything is earthed as far as that goes. My suspicions are that the chassis is connected to mains earth through the PSU and the connectors are not (directly, but have some mains earth referenced leakage on top ?). I can throw tiny sparks when I touch the chassis while pluging in powered USB-Devices, then my PSU goes haywire because it thinks something is wrong.
This then leads to a OS Crash/Freeze and buzzing through the unfed sample buffer of my soundcard.
But if your computer freezes in the same manner withoug plugging something in etc., then i would suspect some fault with your PSU (first guess).
If you can loan an old PSU from somebody, you can test this (maybe not the plugging in issue), and then go on to suspect other parts.
In my experience PSUs after faulty RAM are often the cause of intermittent faults.
PS: Is your monitor by any chance hooked up through a double isolated (no earth) PSU ?
Post by: nctnico on May 01, 2016, 07:45:40 am
The sparks from the USB devices are probably caused by switching PSU wall-warts
Post by: nogood on May 01, 2016, 07:54:37 am
Yes I think so too. I have read in some "sources" that it is a problem of "static electricity", but I think it is just leakage from those PSUs.
Seeing how LED-backlight monitors are now coming with external non earthed supplies, that may very well be the cause of the sparks from the HDMI connector.
Post by: FreddyVictor on May 01, 2016, 09:57:40 am
how old is the motherboard ?
my last 2 pc's have died due to failed capacitors on the motherboard, but I have to say, they were older ones and most manufacturers are using better ones nowadays...
Post by: continuo on May 01, 2016, 10:17:27 am
Download the "EVGA Precision X" Tool from their website, this should be the right tool to downclock the card. Rising the core voltage a tad may also be worth a try   :-/O
Post by: Psi on May 01, 2016, 11:54:26 am
The sound in that video is just the soundcard buffer looping whatever it has in memory after the whole system crashes.
I suspect you are getting rather large spikes coming in on the mains and its crashing the PC. Try a Spike protector on the PC power plug.
But other things to check as well are
- Run Memtest all night long to look for memory errors
- If running dual channel ram try a single stick.
- Remove all PCI/PCIe cards and see if the problem goes away
- Check SMART diagnostics for your hard drive for problems
- Is this PC overclocked? If bought second hand it may have come that way. Maybe do a bios reset to defaults. (Note that windows may not boot with defaults settings if it was installed with non default settings, so you may need to reinstall with defaults set.)
- Check CPU temp
- Check Motherboard for bulging capacitors
- If you are experienced and ok with opening up 110/230v devices then open up and check the powersupply for bad caps
Post by: TheAmmoniacal on May 01, 2016, 02:17:56 pm
I will do some measurements tomorrow evening and give some updates. Had to run off on weekend trip.
Post by: TheAmmoniacal on May 04, 2016, 05:45:45 pm
Ran memtest86+ one more time, passed.
Disassembled my PC, rechecked all connectors, reseated the RAM and M.2 PCIe SSD.
My PC chassis measures 20 ohm to mains earth (why so high?)
If I touch the +12V rail of the ATX PSU to the chassis, I get sparks and the PSU shuts off. The earth leakage breaker does not trip. (Happened by accident!)
Everything in the PC runs well within their rated temperature limits.
Just 10 minutes ago the PC froze again, so none of that helped. Still no clue what to do.
Post by: nogood on May 04, 2016, 07:27:50 pm
PSU ground is referenced to earth, so you just short circuited your +12V and the PSU did the right thing and shut down.
RCD would not trip because of the isolation in the PSU.
The 20 Ohms probably come from a not so good connection between PSU and chassis (usually the 4 screws holding it , maybe with some bad(?) plating on the metal, maybe laquer), but the value seems ok.
Edit: If you measured on the chassis to the ground pin, maybe just push the tip of your test leads a bit harder through the surface.
Post by: R_Gtx on May 04, 2016, 09:03:54 pm
Windows 10 is fairly good at reporting errors:
All Apps > Windows Administrative Tools > Events Viewer
Applications and Service Logs > Hardware Events
may provide some clues.
Post by: casinada on May 04, 2016, 10:50:53 pm
As other people suggested, try with a different power supply but to make your life easier, I would try to use a more basic video card and less memory for debugging purposes. Try to unplug anything unnecessary from the computer and see if the problem goes away.
How old is the power supply? Do a search for problems with your power supply model.
The most common problems computers develop is Power supply, HDD, and Motherboard capacitors.
Good luck :)
Post by: TheAmmoniacal on May 05, 2016, 05:30:56 am
The Hardware Events log is always empty here.
I had long suspected my GPU to be the cause of this issue, but it's not. I replaced the GPU with an older Quadro 1800 card to see if the problem went away, but it doesn't. The PC freezes just the same.  :-//
Post by: amspire on May 05, 2016, 05:39:36 am
As it has been mentioned several times, you really have to change the power supply - even if it is a low-end brand-name 600W supply such as one of the cheap Corsair supplies.
The supply is the No.1 suspect and if it is the supply, everything else you try is a waste of time.
Post by: TheAmmoniacal on May 05, 2016, 06:09:32 am
It would be great if I could just try .. another PSU .. another motherboard .. another CPU .. another set of RAM .. another SSD..
The PSU is almost brand new (under 6 months old), and I can't find anyone else on the internet that has experienced problems with it. How would I test it without replacing it? Voltage logger software?
Post by: amspire on May 05, 2016, 06:18:14 am
The only practical way is to get another supply - even if you think of it as a supply you keep as an emergency spare. Supplies and hard drives are the two items that tend to have a limited life, and it is always good to have a spare supply. I know it hurts buying a second supply when you have a top-quality expensive supply, but swapping is the way these problems are diagnosed.
The only other thing you can do is to send the PC back to the supplier or a PC repair technician and they will try swapping the supply.
Do you have a friend you can borrow something from? If you know a keen gamer, they could easily have a stack of supplies.
Something like the EVGA 100-B1-0600-KR 80 Plus is a good supply and is available in Norway.
Post by: TheAmmoniacal on May 05, 2016, 06:44:28 am
You win, just ordered a 600W PSU (100-W1-0600-K2). Expected delivery in 2-3 days, will report back.
Post by: amspire on May 05, 2016, 06:57:26 am
Your PC is just way to good not to get it working reliably as soon as possible. I think it is 12 cores with hyperthreading. Wow! That would be fun to use.
Post by: TheAmmoniacal on May 05, 2016, 07:28:55 am
I bought it primarily for "hobbyist" computational chemistry and molecular dynamics, running calculations that might take a week. I haven't been able to do this lately, which is a shame :(
Post by: Brumby on May 05, 2016, 01:06:01 pm
The feeling is universal.  It doesn't have to be molecular dynamics - but that is an awesome use.
