Author Topic: Cooking hot dogs with mains electricity  (Read 7093 times)
Offline HalcyonTopic starter
  • Global Moderator
« on: March 18, 2019, 09:07:42 am »
Oh Clive...
Online IanB
Re: Cooking hot dogs with mains electricity
« Reply #1 on: March 18, 2019, 09:12:38 am »
Yes, that was a remarkably sane video. No bangs, flames or explosions. It actually worked.
Offline BravoV
  • +++ ATH1
« Reply #2 on: March 18, 2019, 10:53:42 am »
The electrodes look like galvanized zinc, perfectly safe for human I guess as its used in food container too.
Offline NivagSwerdna
« Reply #3 on: March 18, 2019, 11:00:21 am »
That was a great video but I am a bit skeptical as to the definition of "cooked", instead they seemed to be simply electrocuted.  I'm guessing that the 'hot dogs' were at least partially cooked beforehand if not it is just a machine designed to promote food poisoning.  I do admire the engineering though... who would have speculated that electrocuting food could be a viable food preparation mechanism.
Well worth the watch.
Offline vk6zgo
« Reply #4 on: March 18, 2019, 11:27:50 am »
Similar devices were available in Oz, back in the mid 1960s.
Those used a Mains transformer with a lower voltage, high current secondary, to which was connected the spikes(from memory, they were stainless steel).
In practice, a complete hot dog & roll were impaled on the spikes.
The hot dog looked like a shorted turn to the transformer, high-ish current flowed (limited by the hot dog resistance), cooking the treat.
They weren't bad, from memory, the buns had two slightly charred holes in them, which was not aesthetically pleasing.
Offline amyk
« Reply #5 on: March 18, 2019, 11:32:26 am »
"The power factor of a hotdog is exactly 1." :-DD
The fact that steam is coming out of them suggests internal temperatures high enough to cook meat. They cook from the inside-out, which is more efficient than the traditional method of conducted/radiant heat. That said, a lower voltage and longer cooking time would probably be better for more even cooking.
Offline klunkerbus
  • Electrical Engineer (retired early)
« Reply #6 on: March 18, 2019, 11:44:37 am »
Most if not all hot dogs are "precooked", so all one has to do is heat them up prior to eating.
Our family had one of these or something similar in the late 60's or early 70's.  My memories of it are not all that fond.  Electricity follows the path of least resistance, so not all hot dogs would heat up the same, and even on a given dog some parts would be drier/chewier than the rest.  And then there was often an ungodly bad taste at the ends where arcing tended to occur at the pointed contacts.
The following users thanked this post: NivagSwerdna
Offline vtwin@cox.net
« Reply #7 on: March 18, 2019, 12:41:38 pm »
All hotdogs are shipped pre-cooked. All you're doing is reheating them for consumption.
We had one as well. It was sometime in the 70's from what I recall. Gave the hotdogs a weird flavor, like you, I never particularly cared for it. Plus if I recall correctly the hotdogs were "floppy" and hot with a weird interior texture, opposed to a normal hotdog cooked on a grill.
My parents probably still have it stashed somewhere in a drawer, if I go look. They never throw away anything.
A hollow voice says 'PLUGH'.
Offline ajb
« Reply #8 on: March 18, 2019, 05:48:45 pm »
Are hot dogs typically canned in the UK?  Usually in the US they're vacuum bagged, so not as soggy and limp, and they're usually a bit bigger, too.  I would have expected that Clive's soggy scottish weiners would have made for higher power consumption, but maybe the smaller contact area due to the smaller diameter balanced that out--or maybe the salt content is lower?
Online IanB
« Reply #9 on: March 18, 2019, 05:55:13 pm »
Hot dogs in the UK are in the category of "last resort food item, stored in the pantry in case of emergencies". Thus, they come canned in brine, ready to heat and serve. To prepare them you tip them into a pan and simmer them in their brine until they are hot. Nobody eats them unless real sausages are not available.
« Reply #10 on: March 18, 2019, 05:59:41 pm »
Sounds like another British delicacy, like Branston Pickle and Marmite. I'm surprised my wife doesn't have them in the cupboard.
Online IanB
« Reply #11 on: March 18, 2019, 06:01:08 pm »
That's one of the cultural differences between the UK and the USA. In the USA all sausages I have seen are pre-cooked and just need heating. In the UK all sausages are made from raw meat and need thorough cooking before eating.
(Clive's hot dogs were canned and as with all canned goods are cooked and safe to eat right out of the can.)
« Last Edit: March 18, 2019, 06:05:21 pm by IanB »
Offline CatalinaWOW
« Reply #12 on: March 18, 2019, 06:50:13 pm »
Fair warning.  In the US sausages sold in supermarkets and the like are almost always precooked.  Not so for products sold in butcher shops and other places where you might look for real food.
Your British hot dogs sound much like what is marketed in the US as Vienna sausage.  Nasty, tiny canned sausages suitable only for preventing starvation.  Or if your dog isn't very discerning to disguise the medicines you are wanting him to take.
Offline vk6zgo
« Reply #13 on: March 18, 2019, 11:44:28 pm »
In Australia, what is used in the classic hotdog are/were "frankfurts" or "saveloys" .(The latter is slightly different, & the name seems to have fallen out of use)
They are "pre-cooked", to the extent that they are safe to eat "straight out of the shop".
In use, they are usually boiled, & slapped into a roll with toppings to the customer's choice.
When I was a kid, at Agricultural Shows (local  & State Fairs in US speak), they were boiled "en masse" in what we used to call "coppers" (the large copper tub in which clothes were boiled back in the day).
These were becoming obsolete, but conveniently many had been set up with a heating fire in portable form, & were quickly repurposed by the hot dog vendors.
You could smell the cooking "dogs" all across the Showground.
I don't know what effect all that copper residue had on my generation, but we still seem to be around in droves! ;D
Normal sausages are always sold raw --- Vienna sausages are cooked, or somehow made safe for immediate eating.
Tinned sausages are available, but like tinned anything, are a reasonable snack, but that's it
In recent years, traditional "hot dogs" have come under strong challenge from  the "sausage sizzle", where normal sausages are cooked on a grill or hot plate, & stuffed into a roll in the usual fashion.
Offline helius
« Reply #14 on: March 18, 2019, 11:58:03 pm »
Zinc is not safe for cooking use as its salts are toxic. People have been killed by cooking with galvanized steel buckets.
Food containers are steel plated with tin. Beverage cans are made of aluminum with an epoxy coating.
The metal prongs in this do look like zinc, but may be an alloy such as Zamac or an aluminum alloy. There is probably not much transfer of metal to the food since the hot dogs are not very acidic.
The following users thanked this post: apis
Offline Nusa
« Reply #15 on: March 19, 2019, 01:08:57 am »
https://www.fsis.usda.gov/wps/portal/fsis/topics/food-safety-education/get-answers/food-safety-fact-sheets/meat-preparation/sausages-and-food-safety/ct_index
In the US, if it's labeled as a hot dog, it is required to be a pre-cooked sausage of some description. They're ready to heat out of the package, but most people like them heated first.
If the package is labeled as a sausage, it may or may not be cooked. If not ready to eat, it must be clearly labeled as requiring cooking. Breakfast type sausages often fall in the uncooked category.
Clives antique hot-dog cooker came from the US, so it's made the assumption that you're starting with cooked meats. I think Presto quit selling them about the time the microwave became popular. One minute in their cooker couldn't compete with 30 seconds in the microwave. Although personally in pre-microwave days I preferred them boiled or grilled, not electrocuted.
Online coppercone2
« Reply #16 on: March 19, 2019, 01:30:10 am »
this is fun for a high school class to do (physics) so long its not populated by the stupid
you setup a little party and cook the dogs (maybe do a lab before hand with some simple thermodynamics calculations to department approve)
« Last Edit: March 19, 2019, 01:42:29 am by coppercone2 »
  • Global Moderator
« Reply #17 on: March 19, 2019, 02:23:14 am »
I think its the same here in Australia (although I don't know the specifics around hot dog vs. sausage). A sausage on a bread roll is typically referred to as a "hot dog".
Canned or shrink-wrapped sausages are pre-cooked and are safe to eat hot or cold. They are of dubious quality and are usually made from a paste of the bits of animal leftover, plus a bunch of water and salt.
Fresh sausages very in quality. They can be made from the same sludge as above (usually labelled "economy sausages" sold in supermarkets) or actual real meat with proper herbs and spices (commonly sold in butchers). Either way, they are not hermetically sealed, have a short shelf life, must be refrigerated and must be cooked.
Online coppercone2
« Reply #18 on: March 19, 2019, 02:39:52 am »
I don't know why there is confusion. Every hot dog I saw (frank, hebrew national, etc) is ready to eat out of the box but you can make em a bit safer to eat if you get them steaming hot.
You can microwave ,boil or grill them.
You can get quality dogs too
https://www.snakeriverfarms.com/american-kobe-beef/65001.html?ne_ppc_id=1554858907&gclid=Cj0KCQjwg73kBRDVARIsAF-kEH8Q_gziN8GFbK8lX9Iphl1KBZ5bQNP8Y7VHBk0iTC6TrKjdEoXTqYoaAg6WEALw_wcB
The usual rule of thumb is get Kosher when you are getting hot dogs. Cheap hot dogs are shady as hell.
« Last Edit: March 19, 2019, 02:44:08 am by coppercone2 »
Offline DDunfield
« Reply #19 on: March 19, 2019, 02:28:38 pm »
I had one of these when I was a student.
The composition of the dogs and hence the brand you purchased made a huge difference, with some heating nicely, and some hardly at all.
Only way to tell was trial-and-error .. shopkeepers would just "look at you funny" when you asked "how conductive are these?"
Dave
The following users thanked this post: Richard Crowley, martin1454, duckduck
Offline Richard Crowley
  • KJ7YLK
« Reply #20 on: March 19, 2019, 02:50:38 pm »
Clive did mention that it is "an American novelty here".  Both the hot-dogs as well as the gadget (sent from Canada).
I was raised as a vegetarian and I have never knowingly eaten meat. (I'm sure I have consumed it several times along the way without knowing.) Even back in the mid previous century when I was a kid, there were fake hot-dogs made from gluten/tofu/whatever.  But now there are several different brands of vege-hotdog.  Both canned and vacuum-packed and refrigerated.  Just yesterday at the office cafeteria, I enjoyed a couple of vege-hotdogs made from quinoa.
Interesting that it seemed to operate on 240V much the same as over here on 120V.  Probably at higher heat (because of the higher voltage) so cooks in 1/2 the time, but perhaps not as even as a longer time at lower voltage/temperature.
Offline helius
« Reply #21 on: March 19, 2019, 03:44:40 pm »
If the resistance was constant, you'd expect it to operate at 4x power (P = V2/R). But there could be some non-linear effects.
« Reply #22 on: March 19, 2019, 04:27:28 pm »
Here canned viennas are not exactly known as "food', and in the military they had a rather worse reputation, as the "mystery meat' of last resort, served when there was nothing else available, and the name given to them was worse.
The standard pack is a precooked item in a shrink wrap, either frozen or defrosted, sold as ready to eat out of the pack, though you can buy better ones like Russian sausage, which has a taste to it other than salt with some mystery additive, and which is made from real meat by products, and not from every part of the cow other than the hooves and the horns ( though that is debatable) and the mystery "mechanically deboned chicken", which is a misnomer if ever there was one. Suggest you do not look how they are made if ever you want to eat them again.
Online rfeecs
« Reply #23 on: March 19, 2019, 05:47:38 pm »
Mr. Wizard electrocutes a hot dog:
Hot dogs are semiconductors!  and full of resistors.  At one point he grabs both forks, one in each hand.  Fortunately he switched off the power first.
« Last Edit: March 19, 2019, 06:32:40 pm by rfeecs »
Online IanB
« Reply #24 on: March 19, 2019, 06:08:15 pm »
Of course in Clive's latest video he cooked himself with mains electricity  :o
That was much more adventurous  ;D
