Author Topic: Coolest stereo plug I've seen.  (Read 906 times)
Offline pickle9000Topic starter
« on: July 22, 2023, 09:27:37 pm »
I don't understand the language but the work speaks volumes.
« Last Edit: July 22, 2023, 09:40:06 pm by pickle9000 »
The following users thanked this post: BrianHG
Online BrianHG
    • LinkedIn
Re: Coolest stereo plug I've seen.
« Reply #1 on: July 22, 2023, 09:56:45 pm »
Perfect ASMR.
Offline tooki
« Reply #2 on: July 22, 2023, 09:59:20 pm »
It’s cool machining, but I sure hope he doesn’t intend to use it. The nearly square shoulder of the retention neck could damage certain kinds of contacts in a jack. (It’s supposed to have a significant chamfer.)
Offline themadhippy
« Reply #3 on: July 23, 2023, 12:04:13 am »
weres the strain relief to stop it the cable coming detached  if the cable gets yanked? I'll stick with neutrik thanks
« Reply #4 on: July 23, 2023, 12:27:12 am »
cnc converted lathe and mill, uv cure acrylic, home made chuck lock, super thin lathe cuts, laser cut foam and a wooden carry box.
Online BrianHG
    • LinkedIn
« Reply #5 on: July 23, 2023, 03:20:31 am »
It's just that dandelion.  I would have chosen a rose or tulip.
Offline Mr.B
« Reply #6 on: July 23, 2023, 03:37:07 am »
He does some amazing machining.
Here is the mostly english channel on his youtube: https://www.youtube.com/@BanjoShow/videos
Oops... Wrong one... Try this one> https://www.youtube.com/@wmlevsha1133/videos
« Last Edit: July 23, 2023, 03:45:22 am by Mr.B »
Offline EPAIII
« Reply #7 on: July 23, 2023, 10:22:09 am »
Three words:
Switchcraft
Neutrix
Amphenol
Nuff said!
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
