Author Topic: copper printer  (Read 10540 times)
Offline Deathwish
  • Country: wales
copper printer
« on: August 15, 2015, 01:35:38 am »
seeing how they now have printers for all sorts of things, I wonder if they will ever design a domestic / semi pro copper printer for people like us. might at least save a lot of wasted etching and copper being lost.
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline ataradov
    • Personal site
Re: copper printer
« Reply #1 on: August 15, 2015, 02:05:20 am »
One of the recent AmpHour guests touched on that. Basically, printing copper is hard and requires nasty chemicals, much worse than FeCl.
But that's for ink jet printing. I'm not sure if there is any other economical way.
Alex
Offline TheElectricChicken
Re: copper printer
« Reply #2 on: August 15, 2015, 03:35:35 am »
For chemical free economical PCB's at home, CNC routing fits the bill.
https://www.youtube.com/results?search_query=PCB+CNC+Milling+homemade
« Last Edit: August 15, 2015, 04:45:21 am by TheElectricChicken »
Offline German_EE
Re: copper printer
« Reply #3 on: August 15, 2015, 07:58:47 am »
The last time Dave went walkabout to an exhibition didn't we see someone who made PCBs using conductive ink?
Warren Buffett
Offline ataradov
    • Personal site
Re: copper printer
« Reply #4 on: August 15, 2015, 08:01:16 am »
There are a few projects that use conductive ink, but none of them are printing copper. And the result has one "minor" disadvantage -- you can't really solder it.
Alex
Offline 0xdeadbeef
Re: copper printer
« Reply #5 on: August 15, 2015, 08:13:15 am »
Well, to name two commercial conductive ink projects:
Voltera
Argentum
I guess you can somewhat solder SMD components, but I think it will be a pain compared to a real PCB.
And it's more or less single-layer (even if the Voltera promises to be able to print an isolating layer to allow printing some cross connections) and most probably limited to lower currents.
Offline Deathwish
  • Country: wales
Re: copper printer
« Reply #6 on: August 15, 2015, 08:18:39 am »
If you can make a solid solder into a paste that is spreadable and turns hard with heat then there must be a way to do the same with copper. dilute it to pass through a printer nozzle and even with  multiple pass on a base material then heated in an oven it might work. Then again I am not a chemist or such.
Offline ataradov
    • Personal site
Re: copper printer
« Reply #7 on: August 15, 2015, 08:21:22 am »
Melting point of copper is around 2000 F. That's going to be one hell of an oven. And by the time copper is melted, the board will burn away :)
Alex
Offline Deathwish
  • Country: wales
Re: copper printer
« Reply #8 on: August 15, 2015, 08:24:19 am »
Always with the negative vibes moriarty ( good film that one ) well so is solder but they mix it with other base metals to lower its melting point. so why not copper too as long as the end product has a % of copper in and is conductive.
Offline 0xdeadbeef
Re: copper printer
« Reply #9 on: August 15, 2015, 08:26:57 am »
The silver in the conductive ink is also not molten. The ink is some kind of polymer with powdered silver. There's probably a good reason not to use copper. Maybe oxidation.
Online IconicPCB
Re: copper printer
« Reply #10 on: August 15, 2015, 08:37:12 am »
A bit more on conductive polymer...
many years ago in early nineties, during a visit to Nepcon West in Anaheim, I saw a process for making quick prototypes using printed ( extruded ) conductive  and non conductive "ink".
The process relied on conductive and non conductive polymers as well as having a mechanical milling station to structure copper solderable pads for component mounting.
I returned home and some months later wanted to contact the supplier but they had disappeared and could not be traced.
I guess the idea had merit and someone bought them out to remove the competing technology off the market..OR...
But then back to printing copper. Yes it is possible at room temperature. Just went through the experiment of copper nano particles to activate drilled holes in a PCB.
Pyrolysis at 140C (  for all intents and purposes room temperature ) is possible producing copper nano particles of sufficient weight to seed electroplating process.
Courtesy of soviet era process when like today cold war offered alternative solutions. Chemistry involved is far less toxic and expensive than modern alternatives.
Offline Deathwish
  • Country: wales
Re: copper printer
« Reply #11 on: August 15, 2015, 09:31:36 am »
interesting , any articles online ?
Offline 0xdeadbeef
Re: copper printer
« Reply #12 on: August 15, 2015, 09:51:39 am »
According to Wikipedia, the conductivity of intrinsically conducting polymers (stretch oriented polyacetylene) peaks at 80kS/cm (typical values of commercially used polymers are much worse though) while that of copper of silver is around 7-8 times better.
I also understand that the conductivity of intrinsically conducting polymers changes under influence of acids and bases (as the "doping" is done through oxidation) and they can only be only be processed by dispersion.
So you probably don't need a worldwide conspiracy to explain why the use of intrinsically conducting polymers is limited to certain areas and using metal powders in conductive inks is common practice.
Offline george graves
Re: copper printer
« Reply #13 on: August 15, 2015, 09:59:54 am »
Yea, if you like breathing in fiberglass dust. Some say it's almost as bad as asbestos.  It's particles too small for the lungs to expel.  But I can't find any definitive research on that.
Offline Deathwish
  • Country: wales
Re: copper printer
« Reply #14 on: August 15, 2015, 10:38:50 am »
i suppose one way is to use positive photo resist in the heads and only print out the required circuit to the board ?.
Re: copper printer
« Reply #15 on: August 15, 2015, 10:47:05 am »
Well I wasn't about to use business cards to push the dust into little rows and snort it myself, I'd think using a vacuum cleaner hose and a fan to take it outside through a home made cyclone filter would be the trick.
The main reason I would do it as CNC routing home made is that you can then CNC rout so many other things with the same machine, carve faces into scraps of wood, do engraved labels for your equipment ..
Then attach a laser from an old DVD player and mess with laser cutting.  or a 3d printer head, or a soldering iron for wax or ice, or a pen for old-fashioned plotting, Woo Hoo ! I miss those pen plotters.
Re: copper printer
« Reply #16 on: August 15, 2015, 10:57:36 am »
I'll give you $100 if you snort a line of FG dust.  Please send the check before you do. Ya know, since you won't be able to write a check while in the ICU and all.
Offline Deathwish
  • Country: wales
Re: copper printer
« Reply #17 on: August 15, 2015, 11:04:48 am »
George you wired the neg to the pos didn't you ?, your paying him. better send that cheque now or he may not get to spend it.
Offline Mechanical Menace
Re: copper printer
« Reply #18 on: August 15, 2015, 11:23:35 am »
Couldn't you just use silver conductive inks and then copper plate the result?
Second sexiest ugly bloke on the forum.
"Don't believe every quote you read on the internet, because I totally didn't say that."
~Albert Einstein
Re: copper printer
« Reply #19 on: August 15, 2015, 11:28:08 am »
$!00 is fiat money and worthless. Now if it was an ounce of gold or a kilo of silver.... but then, how would I know you'd cough up the pay as I cough up the crap ?
and how do YOU know I won't just be like this dil$%.
Re: copper printer
« Reply #20 on: August 16, 2015, 11:26:46 am »
Well played.  You sir get an internet cookie.
...but still.  My point is valid.   :-+
Re: copper printer
« Reply #21 on: August 16, 2015, 11:39:06 am »
Why thank you sir.  ^-^
Yes, your point is valid, you can't make an omelet without cracking eggs, and you can't make a PCB without making a mess. ( But you can use a dust extraction system to put that mess somewhere else !  >:D )
Online IconicPCB
Re: copper printer
« Reply #22 on: August 16, 2015, 10:06:19 pm »
Deathwish,
Yes there is online info. That is where I found it.
Look for  Industrial-level quality PCB through hole plating on Instructables.
Online IconicPCB
Re: copper printer
« Reply #23 on: August 16, 2015, 10:10:51 pm »
I have built my milling machine and use the milling process to build professional level both single/double sided as well as multilayer boards.
Present fabrication limitations 0.3mm holes and 6 thou features. Spindle speed and runout at the production speed are critical. The spindle usually runs at 40KRPM but it is capable of 100KRPM in case of very fine tooling.
Offline tautech
Re: copper printer
« Reply #24 on: August 16, 2015, 10:32:11 pm »
Yes, and statistics can be  :-/O to show any point of view the film maker wants.  |O
Fact is Glysophate (Roundup) has a LD50 lower than common table salt.
Avid Rabid Hobbyist
