Author Topic: The precision one-milliohm short circuit  (Read 1149 times)
Offline VellTopic starter
  • "Vell" is Catalan for "old man".
« on: May 30, 2019, 09:18:03 pm »
This happened back in '89 or '90 when I was an electronic midwife, being the first to apply power to newly-assembled switchmode industrial amplifiers. Separate output circuits handled positive vs. negative-polarity outputs, as I recall.
One day, a new one had wrongly scaled output, but only for one polarity.  Each polarity had a one-milliohm, four-terminal current sense resistor, but the scale factor was off by just about two, exactly -- too high.
After probing and measuring, I concluded that the sense resistor was half a milliohm; got and installed a replacement. Same story. Decided to do a four-terminal measurement (as I recall), and both original and replacement were one milliohm.
Now, our PC vendor was not one of the best, and we had occasional shorts. Turned out that there was a one-milliohm short across the sense resistor, likely between the current pads. This short was within 3%, or less.
The 6L6 is /not/ a pentode! It's a beam-power tetrode.
Offline MagicSmoker
Re: The precision one-milliohm short circuit
« Reply #1 on: May 30, 2019, 09:23:55 pm »
Welcome to the forum, but do try to post in the appropriate area. This - and your other posts, actually - really belong in general chat.
Offline Zero999
  • 0999
« Reply #2 on: May 31, 2019, 07:40:48 am »
Interesting. I wonder how stable the short was.
How much current was the shunt passing?
The following users thanked this post: Vell
« Reply #3 on: June 02, 2019, 02:21:48 pm »
How much current? Sorry, have forgotten, but maybe 5 A.
Offline Zero999
  • 0999
« Reply #4 on: June 02, 2019, 04:28:14 pm »
Presumably it was a current measuring resistor?
5A would have been a voltage drop of only 5mV, across 1mR. I imagine the amplifier would have needed be low offset, probably a chopper stabilised op-amp.
« Reply #5 on: June 02, 2019, 07:07:06 pm »
As I recall, the op amp was not particularly special. Board layout, though, was probably skilled.
