Author Topic: "Corroded" blister pack of lithum cells - what's going on?  (Read 981 times)
Offline tom66Topic starter
« on: August 14, 2023, 03:59:02 pm »
This is a weird effect - found this pack of CR2016's in one of my old stores of batteries. The whole pack is "corroded" though there's no obvious leakage from the cells.  Most other cardboard/plastic blister packs of a similar age in the box are fine, but a few others are like this, and they all contain lithium cells.
The cells from at least one pack seemed to test okay at 3V, and the cells are still theoretically "in date".
Anyone know what is going on here?
Re: "Corroded" blister pack of lithum cells - what's going on?
« Reply #1 on: August 14, 2023, 04:24:09 pm »
I would suggest they have been stored somewhere that is either damp or at least regularly so, and the "corrosion" is simply the cardboard breaking down.
« Reply #2 on: August 14, 2023, 04:38:28 pm »
I thought the same at first, but there are cardboard blisters in the box that have not broken down (some Alkaline AA's I grabbed from the local Maplin's before they popped, over 5 years old) - so I had ruled it out as a possibility. I suppose it's not impossible that the cardboard on these cell packs is 'weaker' than the others but it's a peculiar coincidence that only the lithium coin cells have been impacted.
Offline PwrElectronics
« Reply #3 on: August 14, 2023, 06:10:34 pm »
First glance it looked like it got damp and had mold on it.  If not, no idea.
Offline u666sa
  • Country: ru
« Reply #4 on: August 14, 2023, 08:04:48 pm »
They leak gas, then. And it has effect on cardboard box. I think it's a throw out material.
Offline audiotubes
  • Country: cz
« Reply #5 on: August 14, 2023, 10:02:23 pm »
Better in the package than in one of your devices.
GP is about the worst possible brand of batteries. Guaranteed to leak.
I have taken apart more gear than many people. But I have put less gear back together than most people. So there is still room for improvement.
« Reply #6 on: August 15, 2023, 04:51:44 pm »
Maybe it's recycled cardboard for those, and virgin cardboard for the ones that didn't dissolve?   :-//
Offline Gyro
« Reply #7 on: August 15, 2023, 05:35:45 pm »
I thought the same at first, but there are cardboard blisters in the box that have not broken down (some Alkaline AA's I grabbed from the local Maplin's before they popped, over 5 years old)...
If those Alkalines haven't leaked after 5 years, they might actually be safe to use!   :D
Best Regards, Chris
Offline rdl
« Reply #8 on: August 15, 2023, 11:33:08 pm »
Probably there's some additive used in making cardboard to prevent that from happening and to save some tiny amount of money they decided to leave it out.
Offline SmokedComponent
  • Country: si
  • Emitting smoke
« Reply #9 on: August 15, 2023, 11:49:02 pm »
Maybe one of those "baby-proof" batteries, covered with substance than gives them repulsive taste (and it leeched out)?
I have such CR2032 Duracells.
They do taste horrible!
Offline Haenk
« Reply #10 on: August 16, 2023, 08:23:55 am »
I'd rule out the cells - the main damage is not around the cells, but on the other half of the cardboard.
But it really looks like water damage, or maybe a leaky alkaline - which would produce exactly that type of damage.
