Author Topic: Crazy 'Manned Multicopter' must see  (Read 5762 times)
Online Moshly
  • What's wrong with this thing
« on: July 18, 2016, 09:28:33 am »
Wow, this guys is both crazy and a genius (skip to 4:40)
Offline Kilrah
Re: Crazy 'Manned Multicopter' must see
« Reply #1 on: July 18, 2016, 09:42:03 am »
Wouldn't say "genius" as there's really nothing fancy in there, but crazy for sure for daring to use such a thing with known unreliabilities and no backup system...
Offline donotdespisethesnake
  • Embedded stuff
« Reply #2 on: July 18, 2016, 09:45:14 am »
Basically he's invented a flying coffin, he just needs to add the lid.
Bob
"All you said is just a bunch of opinions."
The following users thanked this post: Kilrah
Offline retrolefty
« Reply #3 on: July 18, 2016, 11:22:17 am »
 Yes, who the hell does he think he is, one of the Wright brothers.  :box:
Offline GEuser
  • Is Leaving
« Reply #4 on: July 18, 2016, 11:31:23 am »
That was really good , from what i could figure out he has cross-linked the throttles to the joystick i think ..
Soon
Offline StuUK
« Reply #5 on: July 18, 2016, 11:43:36 am »
Like having the engine kill switch near his feet  :scared:
Offline Muttley Snickers
« Reply #6 on: July 18, 2016, 11:49:26 am »
I thought it was very good, excellent even.   :-+
He could start a hedge trimming franchise, cut and blow in one go.   :)
Want to meet like-minded people?...... join a supermarket shopping queue.
Offline DenzilPenberthy
« Reply #7 on: July 18, 2016, 12:54:40 pm »
Which will be of limited use when, after a millisecond's inattention, he loses both legs at the shin to those props :/
Offline StillTrying
  • Country: Broken Britain
« Reply #8 on: July 18, 2016, 03:20:26 pm »
For this thing to lift off, each propeller would have to be providing about 15 Kgs of thrust, they don't look or sound anywhere near that to me.
CML+  That took much longer than I thought it would.
Offline Towger
  • Country: ie
« Reply #9 on: July 18, 2016, 03:26:11 pm »
Just watching him sit down in it (from the head cam) was hair raising.
He appeared to be alone in the clearing, not recommended when playing with a toy capable of badly hurting you in many different ways.  Even an open field would be safer.
Offline zapta
« Reply #10 on: July 18, 2016, 03:59:42 pm »
Still a safer location than this Maker:
« Last Edit: July 18, 2016, 04:06:12 pm by zapta »
Drain the swamp.
Offline langwadt
« Reply #11 on: July 18, 2016, 04:52:45 pm »
...no backup system...
so just like a regular helicopter
Offline Kalvin
  • Embedded SW/HW.
« Reply #12 on: July 18, 2016, 05:16:29 pm »
Helicopters have a capability to land (even safely) using autorotation, but this one will drop from the sky like a stone.
« Last Edit: July 18, 2016, 05:20:29 pm by Kalvin »
Online nctnico
« Reply #13 on: July 18, 2016, 05:18:56 pm »
AFAIK: The way to make an emergency landing with a helicopter is to make the blades spin as fast as possible during free fall and then use the inertia to create some lift just before touchdown. In theory that is... :scared:
Offline Kilrah
« Reply #14 on: July 18, 2016, 05:24:02 pm »
Well except for the energy a heli can store in the rotor and as speed, and the fact that the heli is made of overengineered, heavily tested and certified components that are very unlikely to fail in the first place, not of hobby 2-stroke motors that pretty much have low reliability by design...
Offline rx8pilot
« Reply #15 on: July 18, 2016, 05:51:36 pm »
While I am far from an expert, but it would seem vastly more stable if the center of lift was above the center of gravity. Also, the rectangular arrangement seems to be a unnecessary stability challenge as well. With all that noted, I would at least consider a helmet and other gear to minimize the blood bath when an engine fails and it tips over. Maybe a quick death is better than grave injury?
I will pass over the the word 'genius' for this guy. He does, however, get an A for the excitement part.
Offline electr_peter
  • Country: lt
« Reply #16 on: July 18, 2016, 06:15:47 pm »
Helicopters can perform autorotation maneuver (i.e. forcing a negative blade pitch to speed up rotor, slowly coming down, then changin to positive pitch near ground and safely touching down), if it has enough height and/or speed and a pilot with necessary skills to do that. It is not a especially hard maneuver for a helicopter pilot. But it may require to change pants afterwards...
Medium to big RC helicopters can also perform autorotation (in addition to flying upside down).
Pilot used so called "single stick" controller (old school type). I am really interested how motors are controlled - I will have look a this video deeper.
Aircraft in video seems dangerous for various reasons. I am most concerned with high centre of mass and potential of single engine failure - it would probably not be able to adjust for 1 failed engine and crash. Limited lifting power is very apparent, it flies just barely.
Offline LaserSteve
« Reply #17 on: July 18, 2016, 06:32:43 pm »
Kudos to the Chinese Guy for building a working Heli, AND teaching himself how to fly it.  However, He's too close to re-discovering the usually fatal "Mast Bumping"  design defect that is present in early  Teetering Hinge  rotor heads.  Mast bumping is avoided by careful flight training, some modern machines still have it as a "feature".   The fact that he got the hinges, rotor balance,  and CG nearly right amazes me. I was really worried until he flew the loop out of the pad area and kept the fuselage at the proper angle.
As for the guy with the "Dead Sled",  I've no comment, other then the structure  ensures his body will probably be somewhat  presentable at the funeral.   Holy marginal dynamic stability, Batman!
"God looks after Fools, Little Children, and ships named Enterprise!"
Steve
« Last Edit: July 18, 2016, 07:05:51 pm by LaserSteve »
"I've Never Heard of a Nuclear Meltdown Caused by a Buffer Overflow"  filssavi
Offline Alex Eisenhut
  • If you can buy it for 4$ on eBay, why design it?*
« Reply #18 on: July 18, 2016, 06:44:44 pm »
The thing looks precarious.  Intuitively, I'd have put the 4 center motors further out and blowing out at a slight angle to get a dihedral. The motors look powerful enough to me; they look like two cylinder two-stroke gas engines. I think, I didn't listen I just watched the coolness! I'd suppose the choice of prop is at least as important as the size of the motors?
*Except AC/DC adapters on eBay. Avoid them all!
Offline ez24
  • L.D.A.
« Reply #19 on: July 18, 2016, 07:09:41 pm »
From a link in the video  (warning sad ending)
All these years I thought it was a 737.  FYI  I would never fly Alaska Airlines
Offline XOIIO
« Reply #20 on: July 18, 2016, 08:00:12 pm »
This is the exact sort of thing I'd do, if I was rich :/
Crazy or not it would be awesome.
Offline langwadt
« Reply #21 on: July 18, 2016, 08:14:00 pm »
the prop has to match the torque/speed curve of the motor, the pitch,size etc. is basically the equivalent of a gearbox
Offline zapta
« Reply #22 on: July 18, 2016, 08:26:09 pm »
Or impedance matching, like a transformer.
Drain the swamp.
Offline Kilrah
« Reply #23 on: July 18, 2016, 08:39:06 pm »
That's a thing that with my experience I could build and fly within a week - but wouldn't do even if I don't value my own life that much. Or just fly above the water like many others have done before him, but then the interest is limited precisely because it's been done to death already.
While it certainly gets you media attention and $ where's the fun in that.
Offline ez24
  • L.D.A.
« Reply #24 on: July 18, 2016, 09:15:24 pm »
How does he steer it ?
To me it looked like the shafts that hold the inner motors moves?
Could it be the RPM change in the motors?
