Author Topic: What connects to SR+ and SR- terminals of Philips Xitanium SR LED driver  (Read 924 times)
Offline ocsetTopic starter
Hello,
In the Philips 75W Xitanium SR LED driver, what should be connected in to the SR+ and SR-  terminals of the connector? (page 1 of datasheet)
Is it an external device which needs powering from the SR+  and SR-  terminals , or is it an external device which provides a powered DALI bus into the SR+ and SR- terminals?
Philips SR LED driver:
https://www.na.mytechnologyportal.lighting.philips.com/dam/file:e722c5b7-2994-4007-95bf-fe967b4449e5/Philips+Advance+Xitanium+SR+75W+0.7A+outdoor+LED+driver+with+expanded+memory+datasheet.pdf
Also, for the following Philips Xitanium LED driver, page 3 of its datasheet shows DALI terminals on its connector. Are these terminals for connecting a powered DALI bus into the product?…….or are these terminals for connecting an unpowered DALI device to the product? (which then receives the powered DALI bus from the product)
http://www.docs.lighting.philips.com/en_gb/oem/download/xitanium/Xitanium_75W_0.12-0.4A_215V_TD_230V_929000852103.pdf
We need to know this because some of our customers want to connect a DALI_device_needing_power_from_the_LED_driver , and some customers want to connect a DALI_device_that_provides_power_for_the_DALI_bus.
We would like to find a LED driver which allows both these types of DALI device connections. It is extremely difficult to find one like this. Do you know of one?
« Last Edit: November 10, 2018, 06:34:07 pm by treez »
