Author Topic: Motorized Fidget Spinner spins itself (How to power rotating motor contacts)  (Read 2250 times)
Offline Kedar264Topic starter
  • Country: in
  • Listen to Your Voice
Hi
I've hacked an ordinary fidget spinner by adding an motor so it can spin by itself
Challenging part was to power the rotating motor contacts but i solved it with some copper tape must check !
This Fidget Spinner Spins Itself forever !!!!! :popcorn:
https://youtu.be/zdAI4vkeANE
Offline 8086
    • Circuitology - Electronics Assembly
Next: fidget spinner phone charger?  :D
Offline Fungus
Forever? Or only until the copper tape wears out.  :popcorn:
Offline Gregg
Put some coin cells in the three lobes and make a weighted switch that will make contact with centrifugal force of an initial spin and you will be a big hit in the free energy forums.  You could even market them.
Offline CatalinaWOW
A little air jet will keep them spinning too.  Not in the wheel house of this forum, but even simpler and the only wear problem is the bearings.  It will also spin it fast enough to worry about structural integrity and it will spin seemingly forever coming down from there.
