Author Topic: Curing transformer hum by use of methylated spirits/shellac?  (Read 7686 times)
Offline cdev
« on: December 20, 2016, 05:13:16 pm »
While looking for info on transformer hum I have read that some old timers faced with that situation (and having eliminated other potential causes of problems) either using an eye dropper or a soak, to some degree re-impregnate transformers with some mixture of methylated spirits and shellac-
Example
https://www.flipclockfans.com/forum/forum/clock-show-and-tell/clock-restoration-and-repair/1346-fix-for-noisy-transformers
Does anybody have any experience with this?
Hummmm.. just found this old post here..   Also, re-mounting the transformer may help.
« Last Edit: December 20, 2016, 08:56:53 pm by cdev »
Online aargee
Re: Curing transformer hum by use of methylated spirits/shellac?
« Reply #1 on: December 21, 2016, 02:42:41 am »
We used to put the transformer in a pot of varnish/shellac/etc and stick it in a bell jar attached to a vacuum pump - just one of the venturi types that attach to a tap (faucet).
Keep the vacuum going until no bubbles rise to the top, every little nook and cranny will be full of the stuff.
Not easy, not hard, just need to be incentivised.
Offline BradC
« Reply #2 on: December 21, 2016, 03:07:20 am »
Huh. I do the same thing with Vodka and Bananas.
The following users thanked this post: FlyingHacker, julianhigginson
Offline Sceadwian
  • Beware those that tell you the way the world is.
« Reply #3 on: December 21, 2016, 04:26:34 am »
You need to keep it really thin so that it gets into the coils but still can evaporate to cure, not sure if it's possible to get really ultra low viscosity epoxy? You'll never 'cure' the hum but you'l probably reduce it.
-Because I be, what I be. I would tell you what you want to know if I could, mum, but I be a cat. And no cat anywhere, ever gave anyone a straight answer.-
Online aargee
« Reply #4 on: December 21, 2016, 04:39:43 am »
Does it stop them humming? (Are you thinking what I'm thinking B1? I think I am B2)
The following users thanked this post: julianhigginson
Offline cdev
« Reply #5 on: December 21, 2016, 04:50:20 am »
One of the posts I saw seemed to say that one could do a much more limited treatment with just a few drops of varnish/methylated spirits when old transformers developed a hum, and often after the transformer dried out it would be found that would cure acquired transformer hum.
Offline tautech
« Reply #6 on: December 21, 2016, 05:01:42 am »
Thermosetting epoxies and phenolics are used for transformers to encapsulate them. They're specialty products.
http://www.globalspec.com/learnmore/materials_chemicals_adhesives/electrical_optical_specialty_materials/insulating_varnishes_impregnating_resins
Practical transformer winding:
https://ludens.cl/Electron/trafos/trafos.html
Avid Rabid Hobbyist
Come visit us at EMEX 15th - 17th February. Hall 1 Stand 1002
https://www.emex.co.nz/
Offline BradC
« Reply #7 on: December 21, 2016, 07:16:15 am »
Dunno, after the first Banana I hum myself, and yes B2 I think I'm thinking what you're thinking.
On topic though, vacuum impregnation with wax is another method that works pretty well. As with all of the vacuum impregnation techniques you do have to manage the vac level so you don't boil your encapsulant. I've done some pretty bad damage to epoxy and 2 part elastomers by getting careless with the vac and boiling it. So much so I built a vacuum controller so I can dial in the required vacuum and a set of solenoids makes sure it stays where it is supposed to. Helps a lot for degassing, vacuum moulding and vacuum filtering sensitive liquids. (plus bananas & watermelons). Vacuum is also a wicked way to get a great steak marinade done in minutes rather than hours, and a great way to cheap red wine (at room temperature) into quite a drinkable brandy / lawnmower fuel.
Don't use the same pot you use for epoxy/wax to do the food or grog, and don't use a fragile container. A vacuum implosion can do a *lot* of damage, make a lot of noise and upset the missus.
RS sell nice little air/venturi vacuum devices for a couple of 10's of $$. So you don't need a machanical vac pump to do it either.
The following users thanked this post: joseph nicholas, julianhigginson
Offline calexanian
    • Alex-Tronix
« Reply #8 on: December 22, 2016, 01:24:16 am »
This sort of thing works for magnetic mechanical hum. Induced hum can be cause by too much leakage inductance. This is a function of poor transformer design. More exciting current than necessary under light load via low primary inductance in usually the culprit. It can induct hum right onto adjacent ferrous things such as the chassis.
Charles Alexanian
Alex-Tronix Control Systems
Offline David Hess
  • DavidH
« Reply #9 on: December 23, 2016, 06:52:28 am »
Use the vacuum chamber to remove the gasses from the encapsulant as a separate step before using it on the transformer.
Offline BradC
« Reply #10 on: December 23, 2016, 07:43:18 am »
Yes, but at higher vaccum levels you actually boil components out of the encapsuant, rendering it "not quite as good as it should have been". Most vacuum aparatus will pull a deep enough vacuum to do damage so you need to temper that. It took me ages to figure out that the "gas" escaping from the epoxy wasn't just very well trapped gas but components boiling (I was using a 2 stage oil sealed vane pump though). Probably not that important for transformers, but when making replacement elastomer bits for printers damaging the rubber can have significant long term effects.
Offline calexanian
    • Alex-Tronix
« Reply #11 on: December 24, 2016, 02:25:13 am »
yeah, a two stage rotary pump is a little too much. typically only a few inches of vacuum is needed. Diaphragm pumps are typically used.
Charles Alexanian
Offline cdev
« Reply #12 on: December 24, 2016, 03:10:13 am »
The end one (the one on the left if you are looking at the front) is the transformer whose hum I'm trying to cure. Its part of a Sorensen triple bench supply.  (the unit by itself would be an XTS7-6) It works, it stays cool as a cucumber while delivering its rated 7 volts at six amps right into a current shunt and meter.. it doesn't even get hot..
 But it hums.
Offline rrinker
« Reply #13 on: December 24, 2016, 05:01:14 am »
 Maybe it just doesn't know the words?
Offline BradC
« Reply #14 on: December 24, 2016, 05:10:18 am »
First thing I'd do is nip the screws up. If that fails, put a bit of tube in your ear and use that like a stethoscope to narrow down the source of the hum to the laminations, windings or something nearby and go from there.
« Reply #15 on: December 24, 2016, 06:17:26 am »
Likely leakage field inducing motion into the steel backplate. Simplest cure is to mill some air cooling slots that run parallel to the laminates, so the current path is very long.
Offline calexanian
    • Alex-Tronix
« Reply #16 on: December 24, 2016, 06:33:02 pm »
Or try wedging some rubber sheet or foam in there. Sounds like the transformer is perfectly fine and you just have, as said before, some induced or mechanical hum. Physical dampening would be best. Just push stuff with a rubber eraser until it quotes down and then figure out what to do from there.
Charles Alexanian
Offline cdev
« Reply #17 on: December 24, 2016, 07:31:27 pm »
 SeanB Thank you for the tube suggestion. Its a useful technique.
Its clear the voltage regulator chips are getting hot. Whether that is abnormal? Maybe not.
Kind of interesting..  I brought out a liquid crystal sheet I have which shows temperature.  (remember "mood rings" ? Like that.. Which shows that visually. (Photos below)  This is basically "poor mans thermography" and in some ways its even more useful than with a $500 camera..
And then I had to clear off the kitchen table for now. So am reading up on voltage and current regulation ..
The LC sheet is a sample from LCR Hallcrest -  http://www.liquid-crystals.com
« Last Edit: December 24, 2016, 08:13:31 pm by cdev »
Offline tautech
« Reply #18 on: December 24, 2016, 08:01:10 pm »
Does the hum change with load ?
As you've a IR gun check a few more components for heating....caps drying out ?
Avid Rabid Hobbyist
Offline cdev
« Reply #19 on: December 24, 2016, 08:14:56 pm »
No, not at all but then again,  is the internal shunt on my meter a good load? it would seem to be..   The meter is rated for 10A current measurement but - probe wires were getting warm. Its an old Radio Shack pre-digital VOM.  I also have a UT61e
What is the best kind of load to use?
maybe a light bulb or a longer piece of copper wire?   The current meter also works. (the voltage side is pinned at 9.99 volts, but the voltage does adjust as its supposed to.. and there is a linear "row of 10 LEDs" volt and current meter which works.)
It also has "sense" wire connections. Its a very nice power supply. Definitely worth the $60 (plus almost $40 shipping) I paid..
the caps look as old as the unit (1986!) but they are not getting hot or bulging, as far as I can tell.
« Last Edit: December 24, 2016, 08:38:20 pm by cdev »
Offline tautech
« Reply #20 on: December 24, 2016, 08:30:06 pm »
Whether it's related to the hum or not I'd be concerned at the temps those 317's are running at.  :scared:
Something tells me they shouldn't be running that hot.........what's drawing the current ?  :-//
Avid Rabid Hobbyist
Offline cdev
« Reply #21 on: December 24, 2016, 08:50:00 pm »
Regardless of ESR status, perhaps those 40 year old Sprague caps all should be replaced.  I think I will send off for replacements, might as well.  I might as well get it out of the way.
The 7V 6A unit has four, the other two units each have two.
Offline tautech
« Reply #22 on: December 24, 2016, 08:58:11 pm »
As they're in a linear PSU ESR is not as important as real value and leakage.
They were a good brand decades ago, I think I'd just test them then make the call.
They should hold a charge for an hour or so but to get some idea, leakage specs are in datasheets of any of the better cap manufacturers and you can do a few simple calcs to find out roughly what it should be.
Avid Rabid Hobbyist
Online Zero999
  • 0999
« Reply #23 on: December 25, 2016, 03:55:57 pm »
How about reducing the temperature for the vacuuming stage? If you put it in the freezer, the liquid will boil at a lower pressure. I0m, aware that it won't cure at low temperatures but once it's been vacummed, the curing can take places at higher temperatures.
Offline cdev
« Reply #24 on: December 25, 2016, 08:31:39 pm »
So, was scanning the old posts on sorensen power supplies and found this old post by tekfan in a 2011 thread about the same power supply as I have, which describes preregulation.
Edit: reading the theory of operation in an online PDF of the 2001 version of the manual (missing schematics) it doesn't mention pre-regulation as far as I can tell.
« Last Edit: December 25, 2016, 09:02:20 pm by cdev »
