So I was watching this:
I have the same charge controller, though a smaller model and a different brand. (Mine is EPEver).
The thing is, mine is "common positive". Automotive electrics are common negative.
My thoughts where, how could you have wired this up to a van at all? I mean the panels much be grounding to the body of the van, no?
And when they connect the "LOAD" - and + to the van 12V system, surely that then forces the charge controller to float at -12V?
Surely this is unwise and could potentially (bad pun) been what cause the unit to combust.
