Author Topic: Curious: Common positive solar on a common negative van?  (Read 1120 times)
Online paulcaTopic starter
« on: August 17, 2022, 07:57:22 am »
So I was watching this:
I have the same charge controller, though a smaller model and a different brand.  (Mine is EPEver).
The thing is, mine is "common positive".  Automotive electrics are common negative.
My thoughts where, how could you have wired this up to a van at all?  I mean the panels much be grounding to the body of the van, no?
And when they connect the "LOAD" - and + to the van 12V system, surely that then forces the charge controller to float at -12V?
Surely this is unwise and could potentially (bad pun) been what cause the unit to combust.
Offline thm_w
  • Non-expert
Re: Curious: Common positive solar on a common negative van?
« Reply #1 on: August 17, 2022, 09:07:36 pm »
Are you saying the case of your MPPT controller is electrically connected to +12V?
Solar panel cells are completely isolated from the aluminum frame. Usually you would ground the frame for lightning/safety reasons.
Offline Someone
    • send complaints here
« Reply #2 on: August 17, 2022, 09:59:25 pm »
No, most panels are floating and its up to the installer to decide where the cells are relative to ground (series panel strings... ).
« Reply #3 on: August 18, 2022, 08:21:53 am »
That's a good point.  I don't know.  It says it's common positive and I believe the 3 DC terminals (panel, battery and load) all have a common bus for +.
I never tested if the case was connected to either.
Offline thm_w
  • Non-expert
« Reply #4 on: August 18, 2022, 08:56:17 pm »
If the case is isolated, and you run proper wires to each component instead of using a chassis as return, I'm not seeing what the issue would be.
Even if its not isolated, it could go into a large plastic enclosure.
