Author Topic: Current testing of battery powered products.  (Read 1522 times)
Offline G7PSKTopic starter
  • It is hot until proved not.
« on: July 09, 2012, 03:35:41 pm »
This is not really a project just something I knocked up for testing current draw of batteries without having to mess with trying to hold probes and batteries and circuit under test. it is just two strips of copper foil bonded back to back with double sided sticky tape and two wire soldered on, it is inserted between the battery and terminal and the meter is connected to the wires, very quick and easy.
Offline N2IXK
Re: Current testing of battery powered products.
« Reply #1 on: July 09, 2012, 07:24:48 pm »
Been using a sliver of double sided copper clad PC board material for the same purpose. Works great!
"My favorite programming language is...SOLDER!"--Robert A. Pease
