Author Topic: Custom "R-core" transformers on ebay  (Read 1346 times)
Offline squibbyTopic starter
« on: March 27, 2024, 10:11:12 pm »
As the thermionic valve freaks on here would be well aware, typical transformers are getting harder to come by with the usual 240 or 110 to 6.3V, 12V, 600V, 175 and many other different combos all wrapped with center taps, different current ratings etc etc.
I bought a custom R-core transformer from ebay to solve this problem, and I can report, it met the specs I gave and it has performed flawlessly to date. They also appear to be quite nice quality. To be fair, they look and feel nicer than a 60 year old worn transformer, and I'm a believer that often, if it looks like it was put together with care, it probably will perform.
I've bought two more now. I gave the specs on ebay, and the seller promptly got back with a price. search for R-core transformer.
whoever is making these does a decent job and very efficiently priced. I just paid 80USD delivered to australia for a pair (yes two) transformers for a heathkit regulated high voltage power supply project I want to make.
« Last Edit: March 27, 2024, 10:14:25 pm by squibby »
The following users thanked this post: lowimpedance, Alex Eisenhut
Online SiliconWizard
Re: Custom "R-core" transformers on ebay
« Reply #1 on: March 28, 2024, 12:23:30 am »
Where are they shipped from?
I would assume these are made in China to get such prices for custom stuff.
« Reply #2 on: March 28, 2024, 03:40:32 am »
Absolutely. They are chinese.
As electronics fans, we know what good stuff is good. We know Panasonic, Nichichon, Rubycon, etc etc and a thousand and one other brands that make good components already.
What I like about forums like this, is that I can learn what unbranded chinese or otherwise manufactured stuff from amazon or ebay has been trialed out ultimately recommended. I've tried these transformers. They may or may not be very good, but....they seem fine to me for for the money. I will buy more if I can't find a second hand 50 or 60 year old transformer that I would expect to pay less for second hand.
Attached photo of what I'm talking about
« Last Edit: March 28, 2024, 03:55:25 am by squibby »
Offline jonpaul
« Reply #3 on: March 28, 2024, 09:17:42 am »
Well, easy to buy lams and DIY any mains trsf.
Many off the shelf EI/EE trsf and lams  readily avail.
For valve (tube) audio aficionados a junked old CTR TV, scope, hifi will have a perfectly fine trsf for filament, B+.
J
Jean-Paul  the Internet Dinosaur
Offline Roehrenonkel
« Reply #4 on: March 28, 2024, 11:05:54 am »
Hi squibby,
thank you for pointing it out.
Is there any data given for breakdown-voltage / isolation?
Or can you perform an isolation-test primary to secondary?
In the old days Block had transformer-kits with the finished primary winding for 220Volts.
Best regards
Offline Zero999
  • 0999
« Reply #5 on: March 28, 2024, 11:31:16 am »
Hi squibby,
Best regards
Going by the pictures, there are two bobbins. Assuming the primary and secondary are on separate bobbins, then it should have excellent separation, so it seems pointless conducting any insulation tests.
The following users thanked this post: Roehrenonkel
Offline jonpaul
« Reply #6 on: March 28, 2024, 02:24:50 pm »
capacitance high  due to copper shading band wraop.
Needs a Faraday shied if Cp=s is to be low.
j
Offline shabaz
« Reply #7 on: March 28, 2024, 04:53:11 pm »
I purchased one of these recently, because I've got a DIY VNA that is supposed to have extremely high dynamic range if powered with a decent supply, and I wanted to build a linear PSU for it with as much filtering as I can reasonably manage. It arrived the other day, I still need to use it.
From a quick initial examination, the outer metal band (copper?) is electrically connected to the stamped metal base. Both are lacquered I scraped at that to do that test.
The yellow/green earth wire is not electrically connected to the outer band or the stamped metal base.
The area where the wires disappear into the transformer looks a bit unusual; it is very hard to tell how they have done it because there seem to be some "elements" of construction (hopefully just for mechanical support, but I cannot tell) between the two bobbins. EDIT: There is an R core transformer discussion that mentions that the primary may be across both bobbins, and the secondary could be across both bobbins.
I will measure capacitance (I think by shorting all the ends of the primary winding, and shorting all the ends of the secondary winding) and then measure between that, and also measure each shorted winding to the yellow/green earth wire too, and to the metal base.
EDIT: Now measured (all primary wires were shorted, and all secondary wires were shorted). Measured in the range of 200kHz down to 100 Hz:
Pri-Sec: 97-99 pF
Pri-Yel/Grn: 99-100 pF
Sec-Yel/Grn: 290-300 pF
Pri-Band/Base: 83-90 pF
Sec-Band/Base: 84-88 pF
« Last Edit: March 28, 2024, 07:28:57 pm by shabaz »
Offline jonpaul
« Reply #8 on: March 28, 2024, 05:27:20 pm »
Normal wiring, see spec sheets.
Test cap:
P1+P2  = RLC high
All S1+S2 = RLC low.
Frame, shield, copper band = guard
Would expect 100..1000 PF Cp=s with NO shield
perhaps 30..100 with guarded shield.
https://canadatransformers.com/faraday-shield/
j
The following users thanked this post: shabaz
Offline shabaz
« Reply #9 on: March 28, 2024, 06:24:01 pm »
I didn't understand what RLC high and RLC low meant* : (
I've added the measurements above to that earlier comment.
While I was at it, for a comparison, I took a normal toroidal mains transformer too (of slightly smaller at 15VA) and shorted the primary ends and shorted the secondary ends, and measured the capacitance to be 210-390 pF (in the range of 200 kHz down to 100 Hz).
*EDIT: Now I realize you meant the high and low Kelvin clips of the LCR meter.
« Last Edit: March 28, 2024, 07:13:45 pm by shabaz »
Offline tooki
« Reply #10 on: March 28, 2024, 08:05:44 pm »
For European customers who have a business they can order through: Multi Circuit Boards makes custom toroidal transformers at very reasonable prices: https://www.multi-circuit-boards.eu/en/pricing/toroidal-transformers.html
Offline jonpaul
« Reply #11 on: March 28, 2024, 08:20:40 pm »
RLC high = hot termina (RED)  of RLC bridge or meter
RLC low = rtn terminal (BLK) of RLC brige  meter
« Reply #12 on: March 28, 2024, 10:14:03 pm »
I’m putting these in power supplies for old 50’s/60’s stereos or a 1940’s condenser checker or an old high voltage regulated power supply…. These are pretty ‘rough’ applications where the difference between a high spec transformer and a basic transformer is unnoticable.  I’m not suggesting one of these for your old tek scope.
That’s why I like old electronics…. Very forgiving tolerances
« Last Edit: March 28, 2024, 11:05:38 pm by squibby »
Online coppercone2
« Reply #13 on: March 28, 2024, 11:16:48 pm »
I would like to see a X core transformer. four windings, no purpose.
« Reply #14 on: March 29, 2024, 05:16:24 am »
I would like a transformer built on a monohedron.
Online coppercone2
« Reply #15 on: March 29, 2024, 07:45:58 am »
I wonder about klien torroids it seems more realistic to the klein bottle then any other flowable thing
« Reply #16 on: March 29, 2024, 09:08:14 am »
To be fair, the torus is a type of monohedron and that exists, but I was more thinking about a more elaborate kind of monohedron.
I'm not sure the Klein bottle is strictly speaking a monohedron. Good question.
