| datetime temp wind cube2 cube3 vcc "2016/5/12 6:22:1" 18.32 0 332 342 5.31 "2016/5/12 6:22:2" 18.32 0 333 340 5.31 "2016/5/12 6:22:3" 18.32 0 332 342 5.31 "2016/5/12 6:22:4" 18.32 0 314 337 5.31 "2016/5/12 6:22:5" 18.32 0 332 341 5.31 "2016/5/12 6:22:6" 18.32 0 331 343 5.31 "2016/5/12 6:22:7" 18.32 0 335 344 5.31 "2016/5/12 6:22:8" 18.32 0 322 340 5.31 "2016/5/12 6:22:9" 18.32 1 341 344 5.31 "2016/5/12 6:22:10" 18.32 3 337 341 5.31 "2016/5/12 1:14:10" 22.19 0 316 281 5.03 "2016/5/12 1:14:11" 22.51 0 317 283 5.03 "2016/5/12 1:14:12" 22.51 0 313 286 5.01 "2016/5/12 1:14:13" 22.19 0 348 289 5.03 "2016/5/12 1:14:14" 22.19 0 345 288 5.03 "2016/5/12 1:14:15" 22.19 0 305 279 5.03 "2016/5/12 1:14:16" 22.19 0 331 282 5.01 "2016/5/12 1:14:17" 22.19 4 355 288 5.03 "2016/5/12 1:14:18" 22.19 3 319 278 5.03 "2016/5/12 1:14:19" 22.19 1 321 282 5.03 "2016/5/11 17:46:19" 35.08 0 314 162 4.25 "2016/5/11 17:46:20" 35.08 0 331 166 4.25 "2016/5/11 17:46:21" 35.08 0 333 170 4.25 "2016/5/11 17:46:22" 35.08 0 304 159 4.25 "2016/5/11 17:46:23" 35.08 0 323 167 4.25 "2016/5/11 17:46:24" 35.4 0 335 170 4.25 "2016/5/11 17:46:25" 35.4 1 334 166 4.25 "2016/5/11 17:46:26" 35.08 2 311 161 4.27 "2016/5/11 17:46:27" 35.08 1 315 164 4.25 "2016/5/11 17:46:28" 35.4 1 340 171 4.25 |
Seems like you'd be far better off doing a regression than just guessing formulae, but whatever works for you I guess...Well, guessing with a bit of maths intuition. I wanted to stay in the y=ax+b complexity.
Do you have a source for "real world" regressions?
Ah, ok, I think it was taught with a totally different name in French, under what menu/help section of Excel should I start with (i am no expert)?Do you have a source for "real world" regressions?
Look at the sheet I linked. Excel, OpenOffice, even Google Sheets will fit a simple quadratic on a series of points and label the curve with the formula.
