This happened back in '89 or '90 when I was an electronic midwife, being the first to apply power to newly-assembled switchmode industrial amplifiers. Separate output circuits handled positive vs. negative-polarity outputs, as I recall.
One day, a new one had wrongly scaled output, but only for one polarity. Each polarity had a one-milliohm, four-terminal current sense resistor, but the scale factor was off by just about two, exactly -- too high.
After probing and measuring, I concluded that the sense resistor was half a milliohm; got and installed a replacement. Same story. Decided to do a four-terminal measurement (as I recall), and both original and replacement were one milliohm.
Now, our PC vendor was not one of the best, and we had occasional shorts. Turned out that there was a one-milliohm short across the sense resistor, likely between the current pads. This short was within 3%, or less.
