Author Topic: Datasheet search - M54HC123FL or M54HCL23FL?  (Read 1052 times)
Offline Toczek13Topic starter
« on: February 12, 2021, 11:29:08 pm »
Hello,
I am looking for datasheet or any info about M54HC123FL/M54HCL23FL (I am not sure what is written on top ones or Ls) ic. I have extracted it from old spectrometer control rack and google wasn't helpfull at all. I would appriciate any help.
Offline Andy Watson
Re: Datasheet search - M54HC123FL or M54HCL23FL?
« Reply #1 on: February 12, 2021, 11:58:03 pm »
Do you have any clue as to what the device does?
Long, long ago, the 74xx series of logic was available as 54xx, which was the military spec'd version. For example:
https://www.ti.com/product/SN74123
(download the datasheet)
Edit: Possibly, the "M" indicates it is an ST device. The 54 indicates it is one of their "rad hardened" devices. - so it's possibly a rad-hardened 74HC123. Note, pin-outs are usually different between 54 and 74 series.
https://www.st.com/resource/en/datasheet/m54hc123.pdf
« Last Edit: February 13, 2021, 12:17:10 am by Andy Watson »
« Reply #2 on: February 13, 2021, 12:09:26 am »
It was close to bunch of 741NC op-amps and  DAC (8 and 10 bits), the brand name of M54... ic is SGS I think.
I made a photo of this IC.
Offline Andy Watson
« Reply #3 on: February 13, 2021, 12:23:39 am »
You didn't mention the SGS :)
It's an ancient ST device from the days when they were known as SGS Thomson:
http://pdf.datasheetcatalog.com/datasheet/SGSThomsonMicroelectronics/mXvqrsx.pdf
The following users thanked this post: Toczek13
« Reply #4 on: February 13, 2021, 12:28:44 am »
Thank you!
It's older than me  :D
Offline jmelson
« Reply #5 on: February 13, 2021, 06:42:16 pm »
Hello,
Your subject line has a typo.  The device is a military temperature grade dual one-shot, basically the 74HC123 in a ceramic glass-frit package.
Look at the 74HC123 datasheet for function and pinout.
Jon
Offline amyk
« Reply #6 on: February 13, 2021, 11:13:23 pm »
What?  AFAIK 54xx and 74xx have the same pinout but different temperature ranges.
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #7 on: February 14, 2021, 01:36:06 am »
The pin numbering is the same only for the DIP packages versions of the 54 and 74 series.
The 54 series was also available in a flat-pack package which typically had different pin numbering to the DIP packages.
Offline newbrain
« Reply #8 on: February 14, 2021, 09:43:12 am »
Eh, you might be right or slightly wrong depending on the date codee on that IC!
Is it 1988 or 1986?
Given the logo, I would go with1986, and at that time it was just SGS, as in Società Generale Semiconduttori, even before the fusion with Thomson!
