Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
issue between the power ground and signal ground
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: issue between the power ground and signal ground (Read 936 times)
annapurna
Newbie
Country:
on:
February 24, 2017, 06:28:24 am »
can we connect power ground and micro controller ground?
what will happen if we make the ground common for both?
please provide some references to understand it properly
thankyou.......
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: issue between the power ground and signal ground
Reply #1 on:
February 25, 2017, 01:10:02 am »
Unless you are an expert, NEVER SPLIT GROUNDS. You are almost always better off using one, large, very solid, ground for everything.
Solve interference issues by not overlapping parts of the circuit.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
b_force
Super Contributor
Country:
Reply #2 on:
February 25, 2017, 06:54:05 pm »
Well eventually you need to connect all ground together.
The question is where. Normally you do this at the point of the exit of the power supply, which you use a big star.
But sometimes you can also use local stargrounds.
If it's really all just digital, i would probably make one big ground plane.
If it's mixed (analog and digital), than you have to do some more work.
Logged
http://www.oneworldconcepts.com/
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
