Author Topic: DC clamp meters? Any thoughts about them?  (Read 4740 times)
Offline BiOzZTopic starter
« on: April 12, 2013, 06:29:28 pm »
I was concidering getting a DC clamp meter like this one here http://www.amazon.com/gp/product/B001TCWL1E/ref=s9_psimh_gw_p60_d0_i4?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1FQ9ETXKMDH3FAG64TJ6&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
i would use it just for inaccurate small measurements and relative accuracy measurements above 5 amps (the best DMM i have goes to 10amp if i want to break the circuit)
whats the performance of these? how good are they? how stable are these?
My one regret in life is learning to speak English on the internet ...
Offline Wytnucls
Re: DC clamp meters? Any thoughts about them?
« Reply #1 on: April 12, 2013, 06:45:43 pm »
Online Smokey
  • Not An Expert
« Reply #2 on: April 12, 2013, 07:03:52 pm »
These appear to be the full specs from the mfg:
http://www.gtc.ca/EN/CM100_EN.html
I don't know anything about that particular brand or model current clamp, but looking at their product page we can add them to the list of people rebadging Brymen multimeters :)
http://www.gtc.ca/EN/CT8030_EN.html
« Reply #3 on: April 12, 2013, 07:23:45 pm »
after watching the video i am pleased and have purchased it!
thanks guys!
Offline smashedProton
« Reply #4 on: April 12, 2013, 07:30:10 pm »
What are you using the meter for that would draw so much current?  I'm curious!
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Offline Wytnucls
« Reply #5 on: April 12, 2013, 07:36:09 pm »
This particular clamp meter is probably made to order by C.E.M, with the specs required by GTC.
« Reply #6 on: April 12, 2013, 07:55:44 pm »
well today i encountered a problem with my stepper motor power supply (home built transformer one) blew the fuse on my 10A meter thats what triggered me but i also work with allot of high current SMPSs and capacitor discharges and such ... i dont plan to go past 50A steady but with peak surges 100A will do me
next up i got to make an adjustable load ... TO THE BUCKET OF FETS!
Online Smokey
  • Not An Expert
« Reply #7 on: April 12, 2013, 09:22:27 pm »
Meters like that really only work with constant signals.  You probably want something with a decent bandwidth for the stuff you are talking about.
::Edit::
Probably should stay away from this guy on ebay, xux2007
See other thread on current clamps.
« Last Edit: April 12, 2013, 09:26:22 pm by Smokey »
Offline notsob
« Reply #8 on: April 12, 2013, 10:03:29 pm »
As an example of low voltage current where a DC clamp meter would be of use. The  starter motor  on a tractor  draws over 200Amp.
However generally accurate measurement is not required so most people use an induction ammeter.
« Reply #9 on: April 14, 2013, 05:22:34 am »
For that, a current sense trafo connected to your oscilloscope would work wonders
Offline Pentium100
  • Country: lt
« Reply #10 on: April 14, 2013, 05:31:21 am »
If I had to measure DC current more often, I would buy a DC clamp meter too. Having to break the circuit to connect the meter is annoying. And the standard meter only goes up to something like 10A. 10A is not a lot...
Offline DenzilPenberthy
« Reply #11 on: April 15, 2013, 01:04:39 pm »
I bought one of these little DC clamp meters a while ago.
http://www.justoffbase.co.uk/Mini-AC-DC-Clamp-Meter-Sealey-MM405?gclid=COns6cvdzLYCFSXLtAodbScAIw
I love it to bits, it makes working on 12v stuff so easy, e.g. automotive and solar stuff.
