Author Topic: DC Power Standard for your home  (Read 7417 times)
Offline SeekonkTopic starter
« on: December 05, 2015, 05:12:56 pm »
A few days ago NPR radio had a teaser about Edison may hve got it right about DC.
http://www.npr.org/2015/12/02/458127706/planet-money-ad-versus-dc-power-grid
I thought it might be about HV DC transmission on the grid allowing allowing
transmission of more power on existing transmision lines.  No, it was about some
large companies like GE trying to create a new standard for powering electronics
in the home.  The claim was wall warts get hot and inefficient and besides they
want DC anyway.  Good luck anyone making sense about what they were saying.
The proposed solution was a super efficient converter per room.  The effort is
to create a standard socket and DC voltage that all future electronics would work off.
Ignore the bad reporting,  The push for this is probably the electric utility companies
that are having to deal with rectified power supplies that only draw current at the
peaks of the cycle.  LED lighting, entertainment electronics, even VFDs for air conditioning.
Resitive type loads are disappearing.  PFC chips in power supplies haven't made a dent in
this problem.
For the future this is a pretty neat idea.  My camp is 100% solar and I run my wall warts off
the raw 52V from the solar panels.  Most of them do work at this reduced voltage and reduced
power output.  The advantage is the 120V inverter only needs to be turned on when the fridge
or other device is needed.  Think of every home having a single 250W panel powering all your
electronic devices. Fits in with Ted Koppel's view of the grid being taken down for months
from terrorist attacks. Grid tie looked like the future but the utilities are now pushing back
and the politicians are working to kill your payback.  A home DC power standard will be the
future for the solar home. This could make a major dent in power use. My solar panels always
produce 100% of their potential solar output.  Any excess power goes to heating water.
Offline kwass
Re: DC Power Standard for your home
« Reply #1 on: December 05, 2015, 05:45:48 pm »
I think that it's about the Emerge Alliance http://www.emergealliance.org/ which is primarily targeted to commercial buildings.  The company they mention in the NPR interview, Nextek Power Systems, is looking to get into the residential aspect of this too.  It's unclear if/when that will happen.
The general idea is that in-building DC micro grids are more efficient to use for alternative DC generating power sources so that they're are fewer AC<-->DC conversion steps needed and battery storage is more readily achieved.  Silly video on this:
https://www.youtube.com/watch?v=2PkJOOA2v6o&feature=youtu.be
« Last Edit: December 05, 2015, 06:02:25 pm by kwass »
-katie
Offline madires
  • A qualified hobbyist ;)
« Reply #2 on: December 05, 2015, 06:04:41 pm »
When you replace the wall warts with good buck converters you can reduce the power usage by about 50% since most cheap wall warts are quite lossy. I power all my network and telephone stuff by a central high efficiency 12V PSU and a few buck/boost/isolated flyback converters for the non 12V stuff. And for redundancy I can add a second PSU.
Offline mtdoc
« Reply #3 on: December 05, 2015, 06:10:46 pm »
The difficulty with broadly adopting this idea in the US for residential use is that electrical codes specify different requirements for DC wiring. Metal conduit enclosed wire runs, DC rate breakers, etc.  That makes implementing this in existing homes very expensive.
Offline rfeecs
« Reply #4 on: December 05, 2015, 06:18:49 pm »
I heard that story on the radio on my drive to work yesterday morning.
I was kind of shocked how much their engineer (named FUND) "dumbed down" the explanation:
FUND: An AC power signal would sound like a siren.
FUND: (Laughter) And DC power would sound more like a steady tone.
« Reply #5 on: December 05, 2015, 10:54:58 pm »
I've read articles where they talk about silicone chips.
I live half the time in two communities.  One you could drive around for two days before seeing solar on a house.  The other has solar on one in three homes.  Fact is solar works and I enjoy being totally off grid.  On my street one in five has a standby generator.  Having you own DC power isn't off the wall thinking.  Just takes a few big players to push it.
Offline madires
« Reply #6 on: December 06, 2015, 12:13:39 pm »
For outdoor use, maybe?  :-DD
I've thought about adding a PV panel plus a buck converter (12V output) to my central DC power setup but a proper lightning protection and grounding isn't particularly inexpensive.
Offline Chris Jones
« Reply #7 on: December 07, 2015, 08:20:51 am »
For Australians, an advantage in DC house wiring is that higher voltages (up to 120V) are allowed to be used before the work legally must be done by a person who has done a 4-year apprenticeship and paid for a government licence, rather than a mere street sweeper, amateur poet, chartered electrical engineer or busker etc. With AC, the limit is lower (50Vrms iirc).
For example one could use 110VDC to wire a house without needing a licence, which would not require particularly fat cables as the RMS current would be much the same as for houses in the USA. I am not at all conviced that this would be safer than wiring one's own house for 240VAC, since DC switches are more prone to arcing. The disadvantage of 110VDC would be that for most appliances a DC-DC converter or DC-AC inverter would be needed. Filament lamps and resistive heating appliances from the USA might work, however the switches are unlikely to be safe when operating from 110VDC.
Offline dexters_lab
« Reply #8 on: December 07, 2015, 09:10:14 pm »
i had thoughts of something similar many years ago
my thought would be to have a central power supply that would step the mains down to 24v DC and distribute it out to low power devices like chargers, lights, digital tv receiver boxes, that kind of thing. It would be smart so when you plug in the device it would request a certain power which the central supply can approve or deny depending on it's maximum loading, if it approves power can be applied to the local socket. I believe USB devices work like this
devices would be enumerated like USB so you can have things like; a light can turn on/off on a timer from the central power controller but it wouldn't matter which socket it was plugged into
i decided it was a pointless system because it would require too many 3rd parties to commit to using it, it would be impossible to get it accepted
Offline calexanian
    • Alex-Tronix
« Reply #9 on: December 08, 2015, 06:19:31 am »
Also do not forget about the galvanic effects. Yes they can be mitigated by periodic reversal of polarity, but that can surface harden and make the conductors brittle over time. DC is however used in some long run high tension line applications. The lines running down from Oregon to Los Angeles known as path 65 is an example. https://en.wikipedia.org/wiki/Pacific_DC_Intertie
As far as use in the house I see it being first applied to off grid buildings for obvious reasons first.
Charles Alexanian
Alex-Tronix Control Systems
Offline eugenenine
« Reply #10 on: December 08, 2015, 11:41:57 pm »
A lot of the ham radio world will use anderson power poles as an unofficial standard.  You can get wall plates with them already.
Offline rdl
« Reply #11 on: December 09, 2015, 03:32:56 am »
It's surprising that houses are still wired primarily with high voltage AC, since most of what get's plugged in the wall can't use it directly. Mains power throughout the house is becoming even less necessary with increasing usage of LED light bulbs and flat screen TVs.
Offline rdl
« Reply #12 on: December 09, 2015, 04:23:12 am »
Well, I did say "primarily". Obviously high power stuff like heating, AC, cooking, etc will still need mains power.
Offline NiHaoMike
    • Facebook Page
« Reply #13 on: December 09, 2015, 06:54:48 am »
What about pulsed DC at 170V or 340V? The pulsing could be such that it would be simpler and more efficient than conversion to AC, yet solve the arcing problem with pure DC.
Offline Zero999
  • 0999
« Reply #14 on: December 09, 2015, 11:09:29 am »
Yes DC is safer than AC at the same voltage/current.
It's the change in current with stimulates the nerves and disrupts the heart.
Once I tried to shock myself with 70VDC. I couldn't feel a thing until I moistened my fingers with salt water and even then I only felt it when the current was interrupted.
Pulsed DC would be more dangerous than steady DC, probably equivalent to the sum of the DC & AC components.
Offline VK3DRB
« Reply #15 on: December 09, 2015, 11:23:35 am »
Pulsed DC can still electrocute, while true DC, even 170V, won't easily kill one.
Wrong. 170VDC, without any current limiting can fry your flesh. And cause heart failure. Try at little as 20 milliamps though your flesh to become toast ("frying current"). Also DC makes muscle contraction constant, making it more difficult to disconnect one's self from the source, compared with AC.
Even plugging together nineteen 9V batteries (a nominal 170V DC) in series may well kill you if you put a sweaty finger on each of the extreme end terminals.
Offline Delta
« Reply #16 on: December 09, 2015, 01:40:46 pm »
170v DC will kill you as soon as look at you.
Please tell me you don't work with anything greater than 5v!
Offline dfmischler
« Reply #17 on: December 09, 2015, 02:54:24 pm »
The DC power standard in use in my home and workplace  is IEEE 802.3af (PoE).  Haven't needed to upgrade to 802.3at (yet?).
Offline Zero999
  • 0999
« Reply #18 on: December 09, 2015, 04:35:51 pm »
170VDC can kill but it's less likely to cause injury than 120VAC.
Offline mtdoc
« Reply #19 on: December 09, 2015, 06:25:09 pm »
I would say it differently. 120 VAC is more likely to kill you (by inducing a fatal cardiac arrhythmia) but 170 VDC is more likely to cause injury ( thermal tissue damage) but could also kill you.
