A friend from Spain showed this to me. The Australian/Japan pins are connected to the same LIVE as everything else...! That means, if you grab it from the back, you'll be shocked!
The pins can be retracted, at which point they are disconnected although the ends are slightly exposed, they are no longer live. However, the lock/unlock switch is very sensitive and it is very easy to accidentally unlock them, at which point the pins become live and exposed, regardless of whether it is plugged in or not. The output socket itself does, at least, use a shutter, but the safety of that system is completely negated by this design fail.
And yet it carries a CE mark, must be faked.
