Hello,
I wanted to share with you a scary, but not unexpected security fault I have just discovered in a cheap chinese hot glue gun. Well, it doesn't even deserve to be called a security fault. It's just a hazardous deadly shameful evil-minded "tool".
I always doubt about the safety standards of such cheap tools, but seriously, this is nuts.
Today, I was applying some hot glue over an aluminum surface. I was grabbing the piece with one hand, the gun in the other and, as I approached the tip of the gun to the metal, I felt that unmistakable tingling of electric current through my hand. First, I just thought the gun might be leaking some current, so I checked the voltage at the tip and... 180V RMS.
Next, I measured the resistance between both plug pins and the tip and, sure enough, one of them was shorted to it.
This is the weapon, in all of its inglorious shame.
I still can't believe such a dangerous thing, and who knows how many like it, are being sold through Amazon without any regulation.
Every time you plug one of those to the wall, you have 50% chance of having a live mains voltage exposed pointy metal nozzle. With this in mind, who cares about the 28 AWG wire, or the 1/4 watt resistor it uses to supply the led.
Btw, ¿any budget, reliable and, juuust a little bit safer, hot gun?
Thank you all.
