Author Topic: Deathcopter 5000  (Read 1801 times)
Offline etiTopic starter
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
Deathcopter 5000
« on: June 05, 2022, 08:39:47 pm »
Would you get in this? Surely you'd have to be a little INSANE...
https://www.reddit.com/r/dji/comments/v5eduv/to_fly_or_not_to_fly/
« Last Edit: June 05, 2022, 08:42:41 pm by eti »
Online tom66
Re: Deathcopter 5000
« Reply #1 on: June 05, 2022, 09:55:05 pm »
How on earth do you control such a monstrosity?  The gentleman in the video surely understands that every engine will produce varying amounts of thrust -- are there drone controllers that can account for the natural instability of combustion engines (torque regulation is poor; response time even more so.)
The following users thanked this post: eti
Offline TimFox
« Reply #2 on: June 05, 2022, 10:02:46 pm »
It's OK:  he's wearing a safety vest.
Online tom66
« Reply #3 on: June 05, 2022, 10:04:33 pm »
It's also good that he's got the tent pegs to make sure it won't take off.  Given my tent lost two pegs in a 20 mph breeze this weekend whilst camping, I have the upmost confidence this will not cartwheel off into oblivion.
Offline jpanhalt
« Reply #4 on: June 05, 2022, 10:12:34 pm »
Just be sure not to wave at the crowds, particularly if you have/had long arms.
Offline james_s
« Reply #5 on: June 06, 2022, 05:15:25 am »
Sure, technologically it's no problem, it can be tuned and made to fly, although it will probably not fly as well as an electric multirotor this is not the first fuel powered one that has been built and flown. There is no way I would get on board though, those little engines are not known for being extremely reliable, those at least appear to be spark ignition but even so deadstick landings of fuel powered RC airplanes are not uncommon.
Offline LaserSteve
« Reply #6 on: June 06, 2022, 12:01:10 pm »
Hand start the engines, with a starter motor,  then climb in to fly. Unguarded propellers without thrust augmenting shrouds.  Bodge tape holding the tach sensors on.  Lovely way to create a widow. Ouch.
Steve
« Last Edit: June 06, 2022, 01:41:53 pm by LaserSteve »
"When in doubt, check the Byte order of the Communications Protocol, By Hand, On an Oscilloscope"
Quote from a co-inventor of the PLC, whom i had the honor of working with recently.
Offline janoc
« Reply #7 on: June 06, 2022, 01:53:02 pm »
Steve
Well, at least he got the center of gravity thing (mostly) right. I have seen such contraptions being built with the pilot sitting on top of the thing!  :o
Offline eugene
« Reply #8 on: June 06, 2022, 03:01:48 pm »
I might consider flying it around very close to the ground. I've seen motorized devices with much less thought put into them.
90% of quoted statistics are fictional
Offline Domagoj T
  • Country: hr
« Reply #9 on: June 06, 2022, 04:45:56 pm »
You have fallen for the rocket pendulum fallacy.
Placement of the propulsion system is irrelevant for the stability in flight. That being said, propellers should be placed up high, but only because you might wish to minimize foreign object ingestion, and delay self decapitation.
Online MT
  • Country: aq
« Reply #10 on: June 06, 2022, 06:37:23 pm »
Insane? Not even close compared to this:
« Reply #11 on: June 06, 2022, 07:27:43 pm »
There is a history of people killing themselves with home made helicopters. Someone's going to get hurt.
Example - don't watch it. The dude dies
Offline james_s
« Reply #12 on: June 06, 2022, 07:41:04 pm »
Aviation development has always been dangerous, lots of professional test pilots have died testing new aircraft prototypes designed by experienced engineers. Technology has improved to the point that it is less dangerous now than it used to be but there is still risk, that doesn't mean people should stop trying. That accident can be a teaching experience on the importance of a helmet among other lessons.
Offline rob77
  • Country: sk
« Reply #13 on: June 06, 2022, 08:00:43 pm »
no, it can't be easily "tuned" to fly...  ;D  look closely at every DIY combustion engine multirotor , they're either unstable or the control is extremely sluggish to account for the response time of the combustion engine.  with combustion engines you would need variable pitch propellers in order to control thrust with immediate response, but you would be even better with gimbaling the engines (aka thrust vectoring) to control direction (every VTOL in production is using thrust vectoring for a reason)
Offline james_s
« Reply #14 on: June 06, 2022, 08:23:00 pm »
I didn't say it was easy, or that it would fly well, but it can be tuned to fly. It's not a good solution but that doesn't mean it can't be made to work to some degree without huge effort. I agree that variable pitch props is a far superior solution.
Offline Red Squirrel
« Reply #15 on: June 06, 2022, 10:33:27 pm »
As a dude with long hair I don't know I like the proximity of those props to my head.  :-DD
