Author Topic: Degrading a capacitor  (Read 3411 times)
Offline nicedwarfTopic starter
« on: October 13, 2016, 10:36:50 pm »
I would like to increase the ESR of a capacitor to demonstrate performance of a normal/low ESR and high ESR.  I'd like to increase the ESR, but not completely destroy it.
Any suggestions?
Thanks!
Offline dannyf
Re: Degrading a capacitor
« Reply #1 on: October 13, 2016, 11:02:25 pm »
Put a serial resistor to it.
The following users thanked this post: blueskull
Online 2N3055
  • Country: hr
« Reply #2 on: October 13, 2016, 11:31:13 pm »
+1. I'm glad I was not drinking water.
LOL , but I was..  :-DD
Dr. Richard W. Hamming
« Reply #3 on: October 13, 2016, 11:33:53 pm »
:-)  yes, for a few reasons adding a resistor in serial is not ideal in this case.
Online Ian.M
« Reply #4 on: October 13, 2016, 11:35:56 pm »
So tear down some dead SMPSUs or CCFLs and salvage the worst ESR capacitors you can find that haven't actually bulged or blown.
Offline DimitriP
« Reply #5 on: October 13, 2016, 11:53:20 pm »
Replacing the capacitor with a  bad one might not be ideal in this case either.....   ;)
Offline stj
« Reply #6 on: October 14, 2016, 12:26:57 am »
freeze it with spray and watch the readings on a meter.
 8)
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #7 on: October 14, 2016, 03:33:33 am »
Call it mean names, i'm sure that will degrade it's spirit ;^)
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #8 on: October 14, 2016, 06:37:29 am »
It would help if you told us which kind of capacitor it is............
If it's electrolytic, you can simply shoot freeze spray at it.  As it gets cold (below 0°C), ESR rises considerably.
If it's any other type, add the resistor...
(Or if you want to prank someone, put AC across it.  Old tech prank: put a 1uF 100V polarized electrolytic inside the equipment end of a power cable.  Like an IEC computer power cable, for instance.  When your colleague plugs it in, the capacitor wheezes rapidly, and frustration ensues... :-DD )
Seven Transistor Labs, LLC
Offline fubar.gr
  • Country: gr
    • Fubar.gr
« Reply #9 on: October 14, 2016, 03:51:30 pm »
I once degraded an electrolytic by applying current limited reverse polarity DC with the intention to increase its ESR
You can see it here: https://youtu.be/AYjnxdvsI1U?t=758
A reverse biased electrolytic behaves kinda like a short circuit so it will overheat rapidly and explode.
But in this video I am using a current limited power supply. By adjusting the current I can make the temperature rise in a controlled fashion, so the capacitor vents but doesn't explode.
But I overdid it and the capacitor ended up with an ESR of over 40 ohms.
Also note that this is a very high quality Panasonic FC cap. A cheap capacitor won't hold for that long.
