Author Topic: Delayed Start in Nose Hair Trimmer  (Read 3027 times)
Offline Boris_yoTopic starter
  • Country: il
« on: December 06, 2021, 07:57:51 am »
Hello,
My nose trimmer starts several seconds after I switch it on.
What could be the reason for that?
I would be curious to disassemble it if need be.
« Last Edit: December 09, 2021, 08:16:16 am by Boris_yo »
Offline BradC
Re: Delayed Start in Nose Trimmer
« Reply #1 on: December 06, 2021, 10:41:12 am »
Thickened or absent lubricant and friction.
The following users thanked this post: cliffyk
  • Country: il
« Reply #2 on: December 07, 2021, 02:23:36 pm »
What thickened and how thickening happens?
Offline Benta
« Reply #3 on: December 07, 2021, 06:33:25 pm »
I really hope you mean nose hair trimmer.   :scared:
  • Country: il
« Reply #4 on: December 09, 2021, 08:15:38 am »
Yes, nose hair trimmer.
Offline Ed.Kloonk
  • Cat video aficionado
Re: Delayed Start in Nose Hair Trimmer
« Reply #5 on: December 09, 2021, 09:10:47 am »
When you get to my age, you find the battery ones no longer cut it.
Eventually you need to change brands such as from Wahl to Husqvarna.
iratus parum formica
The following users thanked this post: tom66, SeanB, Dave, SilverSolder, newbrain, james_s
Offline basinstreetdesign
« Reply #6 on: December 10, 2021, 12:13:28 am »
:-DD
STAND BACK!  I'm going to try SCIENCE!
  • Country: il
« Reply #7 on: December 12, 2021, 07:12:22 pm »
Why? Your hair strengthened with years?
Offline james_s
« Reply #8 on: December 12, 2021, 07:36:58 pm »
Petroleum based greases tend to get thicker with age, I don't know the exact mechanism but I suspect the lighter more volatile components gradually evaporate out. They also may collect dirt and wear products from whatever they are lubricating and that will make it thicker.
  • Country: il
« Reply #9 on: December 16, 2021, 05:27:24 am »
The battery in my trimmer is AA. I just spinned battery in its compartment a few times and the trimmer not only switches on instantly but works better. I noticed this with TV remotes as well and don't know why that happens.
Offline james_s
« Reply #10 on: December 16, 2021, 08:01:29 am »
Oxidation or other contamination on the battery terminals. You might improve things by smearing the ends of the battery with a light coating of dielectric grease.
  • Country: il
« Reply #11 on: December 16, 2021, 03:49:35 pm »
Will wiping 800 grit sandpaper on battery ends and compartment's contacts work too?
Offline james_s
« Reply #12 on: December 16, 2021, 06:01:52 pm »
That will clean it, although 800 grit is probably a bit more aggressive than you need. It won't stop it from oxidizing again though, that's what dielectric grease is for. In most cases it is not needed but this can be an issue in humid environments.
  • Country: il
« Reply #13 on: December 18, 2021, 07:00:09 am »
Dielectric grease is not so popular in my country. We have contact cleaning spray with oil and dry contact cleaning spray. Not sure of difference and whether these sprays can be a decent substitute for dielectric grease...
Also we have WD40 Specialist Contact Cleaner.
And Mr McKenic – Contact Cleaner (Fast Dry) with features:
- Cleans Precision Electronic Parts
- Degreases
- Removes Dirt & Flux
- Improves Electrical Conductivit- Fast Drying
- Safe On Most Surfaces
- CFC Free
Not sure whether it renews conductivity and further protects electronic contacts.
« Last Edit: December 18, 2021, 07:09:25 am by Boris_yo »
Offline james_s
« Reply #14 on: December 20, 2021, 10:24:48 pm »
Dielectric grease is usually silicone grease. The same stuff is sold as silicone vacuum grease and as food-safe o-ring grease. It looks and feels a lot like clear silicone caulk except it never cures.
Offline SiliconWizard
« Reply #15 on: December 20, 2021, 11:03:26 pm »
Although, some people do also tend to have their nose grow as they age. But that's a different problem.
Online Gyro
« Reply #16 on: December 21, 2021, 11:42:35 am »
For the ageing among us, I can see an advantage in a trimmer that provides a delay between myopically searching for the switch and sticking it up your nose.  :D
Best Regards, Chris
  • Country: il
« Reply #17 on: December 25, 2021, 07:03:50 am »
I only know one - Pinocchio.
  • Country: il
« Reply #18 on: December 25, 2021, 08:14:48 am »
This will be good?
Offline james_s
« Reply #19 on: December 25, 2021, 06:41:25 pm »
That's silicone based lubricant, it's a very thin liquid. The stuff you want comes in a tube that you squeeze it out of and has the consistency of toothpaste.
  • Country: il
« Reply #20 on: December 26, 2021, 04:21:01 am »
This will not be good enough for prevention of rust and oxidation on electronics? It doesn't mention protection against corrosion though...
I planned to wipe corroded battery compartments in electric screwdriver and TV remote with isopropyl alcohol and use that silicone spray for protection against rust and oxidation.
