Author Topic: Design your most expensive LED Blinky!  (Read 18125 times)
Offline ZeynebTopic starter
« on: August 24, 2015, 11:34:34 pm »
Let’s assume you’re working for some big American defense company and experience this Dilbert situation:
Instead of the mousepads order you convinced your boss to demonstrate your overengineering skills in the most expensive LED blinky circuit!
You are getting the lead in this project as an EE.
Please ensure you sent as much money down the drain as possible with your design. Please also add as much unnecessary complexity as possible. I’d suggest you would hire methodology consultants as well for the most trivial elements.
However keep it to the field of electronic engineering. How does your design look like and which components would you be using?
Let’s have some laughs!
« Last Edit: August 24, 2015, 11:48:46 pm by Zeyneb »
goto considered awesome!
Offline ConKbot
Re: Design your most expensive LED Blinky!
« Reply #1 on: August 25, 2015, 03:07:30 am »
I'd start looking into making an intrinsically safe, explosive environment rated strobe. You think defense stuff is expensive, oil/gas/mining specialized equipment can be even more so due to the smaller market.
That being said, luminous devices CBT140 would be a good starting point for a LED.
Offline alexanderbrevig
  • Country: no
  • Musician, developer and EE hobbyist
    • alexanderbrevig.com
« Reply #2 on: August 25, 2015, 03:15:06 am »
I'd waste it all on R&D because of my requirements to be World Class in green energy. We need to source the best LED and a very precise resistor and low ESR capacitor.
In fact, I think we would hire someone to make an ASIC for the LED blink RC timing, then have them make the LED with the tiny ASIC already on them. Given they can meet the specs for the worlds best resistor and capacitor (of course they will! their contract says so after all).
Now it's time for me to align with the marketing department, and I'm sure they will have meaningful input for the progress of our product....  :blah:
« Last Edit: August 25, 2015, 03:17:39 am by alexanderbrevig »
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #3 on: August 25, 2015, 03:57:35 am »
Don't forget the international junkets travel - to explore supplier capabilities and new products.
(I've done this before!)
Don't ask a question if you aren't willing to listen to the answer.
  • Country: no
« Reply #4 on: August 25, 2015, 04:01:46 am »
You're hired on my imaginary team as Chief #3 Product Officer, how does it feel Mr. C3PO?
Offline ez24
  • L.D.A.
« Reply #5 on: August 25, 2015, 04:09:42 am »
I like this post  :-+
Offline fivefish
« Reply #6 on: August 25, 2015, 04:35:32 am »
Timing signal for the LED blinky will come from a geo-synchronous satellite sending on/off commands.
Offline bills
« Reply #7 on: August 25, 2015, 04:44:38 am »
Great start than have that control a turbine gen-set.  than add a 50hp. cyclo drive gear box with a VFD to control flash speed and an encoder ( should add 120k to the job)  to trigger the excessively expensive led driver that you guys come up with.
« Last Edit: August 25, 2015, 04:47:28 am by bills »
Never argue with idiots. They drag you down to their level and beat you with experience.
  • Country: no
« Reply #8 on: August 25, 2015, 04:55:54 am »
Cool! Then a change in interval can be used to deduce at which angle the satellite is as well (when moving further away - or close to it on earth). Bonus feature :)
  • Country: no
« Reply #9 on: August 25, 2015, 05:00:04 am »
I promise I'll stop derailing this thread but there is one more take I suddenly realized, and it is EE (though destructive).
One way to go about this would be to take part in a very expensive project, then make a cheap ass LED driver that ends up destroying the thing. Such as making a space shuttle crash or something like that. It would not be the most expensive in terms of buying it, but it would probably be the most expensive in retrospect.  :popcorn:
I need sleep! It's 7AM and I've not slept yet. 2 hours POWERSLEEP go :=\
Offline vk6zgo
« Reply #10 on: August 25, 2015, 05:02:51 am »
Well,first we start with the Fusion Reactor.......
Offline Mr.B
« Reply #11 on: August 25, 2015, 05:12:00 am »
To burn a huge amount of money you have to start out with a fundamentally flawed and impossible premise...
We will power blinky with a batteriser!
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
Offline hamster_nz
« Reply #12 on: August 25, 2015, 05:14:54 am »
I would demand the best reliability and widest operating environment.
So must use MIL-SPEC or Space rated parts, and remember to get it FCC certified.
Offline babysitter
  • pushing silicon at work
« Reply #13 on: August 25, 2015, 05:17:48 am »
  • Use a monitor diode(s) to control brightness in a closed-loop manner. Current control is simply not sufficient!
  • A Trimble Thundertbolt E grade GPSDOCXO is barely sufficient to control blinking frequency as it stability decays when GPS reception degrades. For high-grade customers, consider Microsemi CsIII Model 4310B Cesium frequency standard.
  • make it with pixels, so you can dim certain parts of the beam.
  • Use some kind of radar to measure length of pixel light path, use pixel dimming to guarantee uniform brightnesss everywhere you shine too.
  • HDMI/FBAS/DVI/DisplayPort input too, for use as a b/w (you know, not actually using black light) projector
  • make the configurator software overpriced.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline ez24
  • L.D.A.
Re: Design your most expensive LED Blinky! --->>> $20,000,000
« Reply #14 on: August 25, 2015, 05:35:28 am »
Here is my $20,000,000 solution:
Actually this would make a fun eevblog video  Dave hint hint
We need a freq standard:
This got me thinking about a Josephson Junction that is needed to maintain the freq of the LED
(used by the US bureau of standards)
http://web.mit.edu/6.763/www/FT03/Lectures/Lecture11.pdf
http://www.nist.gov/pml/div686/devices/automated-voltage-standard-ready.cfm
It takes a PHd to operate it, I think the US has two and China one.
Lets use round numbers - $10,000,000 for the freq of of the LED (includes the PHd).  We now need a power supply and an university to assemble the power supply.  Maybe we can get MIT to put it together.
Actually there is someone on this forum doing low temp freq standards !
So lets add another $10,000,000 for the power supply for a total of $20,000,000
Now someone has to furnish the power supply.
So I think for $20,000,000 you can get a LED to blink.
(I forgot the link to the $1,000,000 oscilloscope needed to test this unit)
Offline SL4P
« Reply #15 on: August 25, 2015, 05:55:29 am »
Duplicated (redundant) of course!
  • Country: no
« Reply #16 on: August 25, 2015, 06:00:31 am »
For some reason I cannot leave this riddle, and I think I've got it solved (in terms of most expensive).
This is an LED controlled by an AI. This AI has a near perfect model of the worlds finances. It is wired such that one can buy the LED on, and off. Because the AI is omniscient in the field of economics someone will always see value in changing the LEDs state.
The LED will not stop until the AI controls half or more than half of the worlds total economy, at which point no one can no longer pay to change the state of the LED.
It's been a long time since I've had so much fun! Thank you Zeyneb :)
Indeed.
Offline Psi
« Last Edit: August 25, 2015, 06:42:22 am by Psi »
Offline NiHaoMike
    • Facebook Page
« Reply #18 on: August 25, 2015, 06:11:16 am »
How about roughly 8.3 million 1W RGB LEDs to make the world's biggest 4K display? (Or make that 5K if you want.) Install it in Las Vegas and bring back the drive in theater.
Offline Psi
« Reply #19 on: August 25, 2015, 06:13:18 am »
How about that many of what I just posted  :-DD
Offline SL4P
« Reply #20 on: August 25, 2015, 06:16:49 am »
Powered using Batteriser to gain the most from the finite resources of the planet...
Offline ez24
  • L.D.A.
« Reply #21 on: August 25, 2015, 06:20:26 am »
Come on guys - you need to add the price tag to your solution.
Mine was $20,000,000
Give me $20,000,000 and I will put together a very very accurate LED blinker.
Offline Psi
« Reply #22 on: August 25, 2015, 06:43:30 am »
I did mine on the bus, it was hard enough to manage using digikey and webbrowse at the same time. Let alone the calculator  :-DD
Edited it now.
The total is $243,027
And if you made a 4K display using it
243027 * 4096 * 2160 = $2,150,147,358,720
  • Country: no
Re: Design your most expensive LED Blinky! --->>> $120.000.000.000.000
« Reply #23 on: August 25, 2015, 07:18:55 am »
Mine is about $120.000.000.000.000+  (half of world capita per 2013, outdated number but hey..) though I know I'm cheating. There would be some EE with designing the hardware to run said AI though ^^
:clap: :)
« Last Edit: August 25, 2015, 07:47:36 am by alexanderbrevig »
Offline ez24
  • L.D.A.
Re: Design your most expensive LED Blinky! --->>> $2,150,167,358,720
« Reply #24 on: August 25, 2015, 07:23:05 am »
Don't forget the JJ so that adds up to
$2,150,167,358,720
God I hope the politicians do not hear of this, they will try and convince us that we need this
