Author Topic: DIAC in a pinch replacement  (Read 8074 times)
Offline Waifian
« on: December 16, 2010, 10:21:57 pm »
Would anyone see a problem with replacing a DIAC rated at 30 volts with two Zener diodes back to back with the same rating or close to it? They should respond about the same I would guess, aside from the extra forward voltage drop.
This for an in a pinch repair of a CFL circuit.
Offline Zero999
  • 0999
Re: DIAC in a pinch replacement
« Reply #1 on: December 16, 2010, 10:25:19 pm »
No a zener diode is not the same as a DIAC.
A zener maintains a similar voltage across it as the current is varied. A DIAC behaves like a spark gap, once the firing voltage is exceeded, it conducts until the current drops below a certain level. A DIAC can be used to make a relaxation oscillator, a zener can't.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: December 16, 2010, 11:14:51 pm »
pair of zeners plus a triac is probably closer.
Day Job: Mostly LEDs
Offline Waifian
« Reply #3 on: December 16, 2010, 11:41:34 pm »
I see. I thought there may be a problem. Thanks for the quick response.
Online NiHaoMike
    • Facebook Page
« Reply #4 on: December 17, 2010, 05:22:54 am »
If the diac is used in the startup circuit, you might be able to use small bipolar transistors instead. Connect the emitter to the more positive side, the collector to the more negative side, and do not connect the base. 2 or 3 of those in series would get you pretty close to the 30v level. Not sure how many cycles it would work for but I have made a pulse generator using that principle and it has worked fine over a few hours at a repetition rate of about 80Hz, so it should last the life of the bulb given it's only used once every startup.
Offline Zero999
  • 0999
« Reply #5 on: December 17, 2010, 08:08:05 pm »
The LM431 plus a bridge rectifier and a TRIAC will give an adjustable firing voltage from 3.7V to 37.2V, more complicated but more flexible.
Surely it's cheaper to just get a suitable DIAC though?
Is it a dimmable CFL ballast? DIACs are normally used to ensure the TRIAC fires reliably and symmetrically.
Offline Waifian
« Reply #6 on: December 18, 2010, 02:19:06 pm »
I just ordered one. Cheap plus shipping. I was in the hopes of making something that would respond the same with parts I could find around. I appreciate the input.
I have never worked with diacs before so I ordered some extras to play around with them.
Also as a side note I can see a reason why Dave hates cats. They are always messing with what you are working on. Stealing parts to play with knocking things over when you aren't looking. That may be it's way of trying to help haha.
