General => General Technical Chat => Topic started by: J4e8a16n on July 11, 2013, 09:45:58 pm
I checked an integration 'error?' in my book . See the red ! .
Unfortunately the book is in french. Anyhow . . .
Yeah, should be -1/3 ln |5-I|. Somebody missed a factor of three...
In my experience you don't usually make it far into a textbook with a bunch of math before you find an arithmetic error. Maybe my school just picks shitty books, though...
Hmm? Let's work it backwards:
f(I) = -1/3 ln(15 - 3I)
Let u = 15 - 3I, then df/dI = (df/du)(du/dI), where
f(u) = -1/3 ln u
So:
df/du = (-1/3)(1/u)
du/dI = -3
df/dI = (-1/3)(1/u)(-3) = 1/u = 1 / (15 - 3I)
Which is what the book has.
So what did I get wrong?
Actually, you're right, thank you!
The catch here is that we came to different answers through different methods, but both are correct because of the constant that is being ignored.
ln(5 - i) = ln(15 - 3i) - ln(3)
And ln(3) is of course a constant.
(I used a lowercase i for legibility)
Kind of ashamed I missed that, I used to grade math papers... :-[
Why not that way?
integration sign ((1/ (15-3i) ) dI) =
ln|(1/ (15-3i) | =
-ln|(15-3i) | =
-|15-3i| = e^(t-C)
and be stuck with no 1/3 :-/
Why not that way?
ln|(1/ (15-3i) | =
-ln|(15-3i) | =
-|15-3i| = e^(t-C)
Because your working is wrong at the line indicated in red. The antiderivative of 1/x is ln x, and you are missing a factor of (-1/3):
http://www.wolframalpha.com/input/?i=integrate+1%2F%2815-3i%29+di (http://www.wolframalpha.com/input/?i=integrate+1%2F%2815-3i%29+di)
substitute u = 15-3 i
du/di = 0-3
and du = -3 di:
du/-3 = di
1/-3 *du = di
ok
-1/3 log(15+3i)) constant = t- C
-1/3 log(15+3i)) = t- (C +constant)
log(15+3i)) =-3( t- C)
Why Wolfgang say?
Substitute back for u = 15-3 i: = -1/3 log(-3 (-5+i))+constant
Which is equivalent for restricted i values to:
Answer: |
| = -1/3 log(5-i)+constant
du/di = 0-3
and du = -3 di:
du/-3 = di
1/-3 *du = di
ok
Be careful with your signs. In several places there you have changed a "-" into a "+". If you do that in a real problem you will lose marks in a test, or build something that doesn't work the way you expect...
For a long time, almost every paper and book I read had errors in the equations, probably so that those who don't understand the maths can't make use of them.
