Author Topic: Lower gain feedback transistor outputs more power on HV trans secondary, why?  (Read 181 times)
Offline gkmaia
  • Electronics Hobbyist
I got a few Lecroy(siglent) WaveAce.
In one of them, the LCD backlight was a bit dim and I suspected the inverter was not supplying enough power to the backlight.
So I replaced Q3 and Q2 for new ones and backlight now is much brighter.
When I replaced them I tested both the old and the new one on my BK curve tracer. These are the results:
- OLD D1802 / Beta: 350 / Display brightness LOW
- NEW D1802 / Beta: 150 / Display brightness HIGH
As Q2/3 drive the oscillation on the primary I am curious to understand why a lower gain transistor on primary/feedback outputs more power on the secondary
Offline Zero999
  • 0999
My guess would be that having a lower beta, it's not driven so far into saturation, therefore will turn off faster, resulting in lower switching losses and higher efficiency, so a brighter light.
The following users thanked this post: gkmaia
