Author Topic: Special type of ribbon cable  (Read 1410 times)
Offline fx991exTopic starter
« on: December 27, 2018, 02:28:04 pm »
I am looking for a ribbon cable that matches the attached drawing.
I made the drawing based on the ribbon cable on the attached picture.
I have looked on tme, mouser, arrow, farnell, rs components, digikey and arrow but I haven't find anything similar.
« Last Edit: December 27, 2018, 02:30:31 pm by fx991ex »
Offline MrMobodies
Re: Special type of ribbon cable
« Reply #1 on: December 27, 2018, 02:48:15 pm »
High voltage flat ribbon cables.
Found some at RS components:
Five way 11.89 mm in width:
https://uk.rs-online.com/web/p/flat-ribbon-cable/8158258/
Four way 14.33 mm in width:
https://uk.rs-online.com/web/p/flat-ribbon-cable/8158286/
I know I have seen them once before and one in an audio amplifier for high current inbetween boards.
It was a long time ago since I have seen them.
UL4411 XL-PE halogen free cross-linked flat ribbon wire for computer wire rate high voltage.
https://www.globalsources.com/gsol/I/Flat-cable/p/sm/1079316308.htm#1079316308
« Last Edit: December 27, 2018, 03:16:06 pm by MrMobodies »
« Reply #2 on: December 27, 2018, 04:14:41 pm »
I am looking for the exact same cable. Check out the drawing.
Offline Vtile
  • Ingineer
« Reply #3 on: December 27, 2018, 06:20:50 pm »
Maybe contact / search ie. Prysmian, Murata, General Cable Corporation etc. more special cable companies ??
« Last Edit: December 27, 2018, 06:23:33 pm by Vtile »
Offline MrMobodies
« Reply #4 on: December 28, 2018, 06:37:35 pm »
Sorry about that I know you said something about a drawing but I didn't notice the pdf file in the attachments until now.
28AWG 19x41
Edit: Oops put cm by mistake.
Total width: 4.3mm cm
Ribbon height: 0.25mm cm
Cable height: 0.7mm cm
1.27mm cm ribbon spacing inbetween cables.
0.88mm cm ribbon spacing on both ends.
« Last Edit: December 29, 2018, 01:02:11 pm by MrMobodies »
Offline donotdespisethesnake
  • Embedded stuff
« Reply #5 on: December 28, 2018, 11:17:31 pm »
28AWG 19x41
Total width: 4.3cm
Ribbon height: 0.25cm
Cable height: 0.7cm
1.27cm ribbon spacing inbetween cables
0.88cm ribbon spacing on both ends
The dimensions are mm not cm!
Bob
"All you said is just a bunch of opinions."
