Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
DIL switch
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DIL switch (Read 2440 times)
slashguitar
Contributor
Country:
DIL switch
on:
November 27, 2012, 02:34:05 pm »
Hello,
I need to switch 8 data lines simultaneously ON or OFF. Has anyone seen a DIL switch where all the switches are connected together.
What other alternatives do I have(It needs to be a mechanical switch-low voltage low current)
Thanks
Logged
G7PSK
Super Contributor
Country:
It is hot until proved not.
Re: DIL switch
Reply #1 on:
November 27, 2012, 03:09:13 pm »
You could glue a bar across all the toggles of a normal dil switch so that they can all be operated as one.
Logged
mikeselectricstuff
Super Contributor
Country:
Re: DIL switch
Reply #2 on:
November 27, 2012, 03:41:18 pm »
Digikey stock some 4-pole ones, but expensive. As above, a standard switch with maybe a piece of PCB glued carefullt to operate simultaneously.
I have seen 8-way 0.1" jumper blocks, which may be an alternative :
http://uk.mouser.com/ProductDetail/FCI/69145-208/?qs=sGAEpiMZZMtsLRyDR9nM1wH1ETOqFdV87Hxqogqwflk%3d
Logged
Youtube channel
:Taking wierd stuff apart. Very apart.
Mike's Electric Stuff
: High voltage, vintage electronics etc.
Day Job
: Mostly LEDs
senso
Frequent Contributor
Country:
Re: DIL switch
Reply #3 on:
November 27, 2012, 03:55:50 pm »
An octal buffer with a single DIP switch connected to the enable pin, would that work?
Logged
ecat
Country:
Re: DIL switch
Reply #4 on:
November 27, 2012, 04:07:18 pm »
Not cheap but a pair of 4-poll or 6-poll wafer switches on one shaft?
http://uk.farnell.com/jsp/search/browse.jsp?N=2031+204324&Ntk=gensearch&Ntt=wafer+switch&Ntx=mode+matchallpartial
I'm sure you could once get stacking latching push button switches - my old man used to build studio mixing desks, but the best I can find is this 6-poll Alps
http://uk.farnell.com/alps/spuj195500/switch-6pole-latching/dp/1123859
Two of these, or the 4-poll equivalent and some sort of push bar?
Last Edit: November 27, 2012, 04:10:10 pm by ecat
Logged
slashguitar
Contributor
Country:
Re: DIL switch
Reply #5 on:
November 27, 2012, 05:01:58 pm »
Thanks for the suggestions. I think I am going to use the jumper blocks mike suggested
The ones from Alps also look great but they're a bit too big for my application.
Thanks,
Mihai
Last Edit: November 27, 2012, 06:44:09 pm by slashguitar
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
DIL switch
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
