So if you ever come across to this: http://www.ebay.com/itm/172031363750 (all power supplies cost same).Ordered one less than 13€ and opened it, looked inside, braced myself for flashy magic smoke but that darn worked!Well anyway it is sold as 220Vac unit but its main capacitors (2) are rated for 250V (should be 400V), 680µF 105C, made by Rubicong Well anyway output capacitors (3) are rated for 25V 3300µF 105C made by ThongX Also bridge rectifier is supposed to have a heatsink according to PCB but mine is missing All other ElCaps are made by ThongX.And then soldering quality is great because they clearly have a wave soldering machine! Bad news is all components are trough hole and some component legs are very long so I have about 0.1 - 0.2mm clearance between mains and ground because somebody didn't cut the leg.Otherwise design seems to be pretty okayish for cheap chinese power supply.Pics: http://hal.garde.fi/~fireflower/kuvia/projektit/kotostyskone/20160502_001.jpghttp://hal.garde.fi/~fireflower/kuvia/projektit/kotostyskone/20160502_002.jpghttp://hal.garde.fi/~fireflower/kuvia/projektit/kotostyskone/20160502_003.jpgSo do you think it is worth of 12,5€?
