HV JFETs are once again* available, this time in SiC flavor, for high power switching application.
They're on the boutique side, expensive. Some are mil-spec, covered in gold, $100 and up.
*Or they were. I think they're going away, enough to support legacy only. I think the timeline is, back when SiC was just getting good enough to make transistors out of, they went for the easier junction types first: BJTs and JFETs. BJTs of course stink for speed -- the carrier lifetime is even longer than in silicon, so you get BJT t_stg and diode t_rr much longer than comparable Si devices. (Or, well, Si body diodes are (necessarily!) pretty crummy too, and the SiC parts are probably subject to the same limitations.) These were also cascoded with low voltage parts for speed, or left as-is for direct drive. Later, MOSFETs were perfected, with easy drive requirements (if at odd voltages). I think IGBTs are here now too, although I still only see research articles using 10kV SiC IGBTs, nothing actually for sale anywhere.
