Now that I'm spending yet another saturday re-sorting a divider box that I dropped spewing screws all over the place, I've had enough.
I have some SMD resistor/cap assortment boxes which have lids over each individual compartment, and a lid over the whole thing so it's more rugged when moving around.
While these are fine for tiny SMT chip resistors, the individual compartments are too small for anything much larger. Think screws in this case, but I also have things like SMT relays, various through hole components, connectors, and so on. All probably need around a 20mm square compartment at the smallest, but some will need larger compartments. Right now I'm keeping these in plano divider boxes which work really well until I drop a box.
I swear that I saw on aliexpress or similar small boxes which were around the size of an individual divider in these boxes (~20mm square, maybe with options smaller/bigger) that each had a lid, and that you could join together into one system as they slid together and interlocked. The ones I saw I remember had some sort of harder colored plastic on the base square part, and the lid I think was out of a clear material. Of course my searching hasn't turned up anything but I probably haven't used the right term.
I'd also be happy with something like the SMD one I have where all of the compartments are individually lidded with a lid over the top to keep them all closed but with larger bins.. However, what I don't want to do is to buy some of the cheap "pill organizer" style where the lids are flimsy, and open when you look at them the wrong way. The plano divider boxes have firm latches which don't open unless you want them to.
Does anyone know where I can get something like I describe?
