Here's a fresh example, the one I'm reading right now.
TI's CD74HCT132:
https://www.ti.com/lit/ds/symlink/cd74hct132.pdfIt's either that I don't know how to read and understand datasheets, or it has not been QA'ed and is a result of some quick copy-pasting.
section
9.2.1.2 Input ConsiderationsThe CD74HCT132 has CMOS inputs and thus requires fast input transitions to operate correctly, as defined in
the Recommended Operating Conditions table. Slow input transitions can cause oscillations, additional power
consumption, and reduction in device reliability.
Fair enough. Now, how fast should "fast" be? Let's see the mentioned table... only to find that it does not contain any specifications on the required input transition timings.
And the very next paragraph says:
The CD74HCT132 has no input signal transition rate requirements because it has Schmitt-trigger inputs.
Of course, the Schmitt-trigger inputs are in the product title. But... why does the first paragraph that I quoted above state that the device
requires fast input transitions? Looks very much like an overlooked copy-paste from another datasheet to me.
Next,
Unlike what happens with standard CMOS inputs, Schmitt-trigger inputs can be held at any valid value without
causing huge increases in power consumption. The typical additional current caused by holding an input at a
value other than VCC or ground is plotted in the Typical Characteristics.
...unless I fail to see it there, the mentioned plots are not present in the Typical Characteristics section.
Finally,
Refer to the Feature Description section for additional information regarding the inputs for this device.
But there is no section named
Feature Description (do the datasheet writers not use tools such as LaTeX that can substitute the section names, links, and page numbers dynamically, referenced by internal id?).
Additionally, there is no specification for the minimum time during which an input must be held high or low to be registered as such, whereas it is one of important characteristics of logic ICs.
This one is definitely not among the better part of the datasheets that I've ever read.
Curiously, it does contain a "submit document feedback" link. I'll try it!
