Poll
How do you pronounce soldering?
Souldering
15 (8.9%)
Soldering
98 (58.3%)
Saudering
55 (32.7%)
Total Members Voted: 164
Author Topic: Does anyone else pronounce "Soldering" as "Saudering"?  (Read 44585 times)
Offline lowimpedance
  • Watts in an ohm?
Re: Does anyone else pronounce "Soldering" as "Saudering"?
« Reply #75 on: May 05, 2014, 06:50:31 am »
Some years back,when I got into oxy-acetylene welding,books from the main supplier of such gear in Oz referred to what is commonly known as "brazing" (using a torch & filler rod), as "braze welding" to distinguish it from the practice of brazing using a forge.
Neither process,although they both fit your definition,is called "soldering".
Then,just to confuse things,the same process,using silver alloy filler rods is commonly known as "silver soldering"! ::)
Indeed, and these 'types of soldering is generally referred to as hard soldering, where as the tin lead variety is soft soldering !.
Offline London Lad
« Reply #76 on: May 05, 2014, 09:09:03 am »
"L" is silent here.  Soddering, to be sure.  I think the bigger question is, "Regardless of how you pronounce it, is it acceptable to call soldering welding?  Am I the only one annoyed by that?  I see that so often, I'm beginning to wonder if that is now acceptable?   I've only seen it in text.  Maybe they're pronouncing it "wedding?"    :D
You can meld two wires by soldering.  It's incorrect to call it welding since welding requires melting of the base metals.  Soldering dissolves the base metals and though it's essentially an alloying process, no base metal is ever melted.  It would be no more correct to drop a piece of metal into a vat of acid, wait for it to dissolve, and then say that the metal was welded to the acid.
Soldering is joining two metals with a filler metal of a lower melting point.
Welding is joining two metals with a filler metal of the same melting point.
I was taught that brazing was still soldering as the filler was usually brass ie softer than the metal being joined but this was referred to as hard soldering.
Offline XOIIOTopic starter
« Reply #77 on: May 05, 2014, 12:18:11 pm »
Long story short: In English is it "solder", in American English it is "sodder". People who say "sauder" are just wrong.
Well, when I threw this poll up the sauder option and sodder were the same pronunciation in my mind, but maybe you are thinking it would be pronounced more like sowder?
I guess these are the problems with talking about pronunciation over text lol
Offline deth502
« Reply #78 on: May 06, 2014, 01:52:22 am »
way i learned it was welding required the melting together of the filler with the base metal (or just the melting of the base metal if no filler is used)
brazing and soldering, well, basically, the same thing. the processes and theories are all exactly the same, the base metal is not melted together with the filler. the only difference between brazing and soldering was the temperature at which it occurred,although i do not remember where soldering stopped and brazing began, but it is somewhere around the temperature where you would switch from a common plumbers torch to an o-a torch.
« Reply #79 on: May 06, 2014, 10:29:48 am »
"Sauder" is pronounced with an elongated "a", kind of like "saw-der". A lot of Americans on YouTube say it that way, but I'm struggling to think of an example. Connor Wolf perhaps? Sounds Germanic to me.
Other say "sodder", with the stress on the double "d". Limor Fried says it that way, nearly spewed coffee over my keyboard when she first suggested some kid should have fun with his buggering iron. She is based in NY I think, is that a NY accent?
buggering iron? lol
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #80 on: May 06, 2014, 12:43:13 pm »
She lives in NY now but I'm not sure that she's from NY.  That's a somewhat midwestern US accent, to my untrained ear.  I'll listen closely next time I hear her and I'll update this if I think I'm wrong.
Offline Stonent
« Reply #81 on: May 06, 2014, 01:21:27 pm »
What about Salmon?
It wasn't until my 20s that I ever heard an adult pronounce the L.
And to go along with Cool HWhip, how about HWill HWheaton?
So do you pronounce the L in these words?
calm
palm
half
calf
chalk
talk
walk
could
would
should
colonel
And what about the "F" that isn't in Lieutenant?
« Last Edit: May 06, 2014, 01:30:41 pm by Stonent »
Offline vk6zgo
« Reply #82 on: May 06, 2014, 02:04:23 pm »
What about Salmon?
calm
palm
half
calf
chalk
talk
walk
could
would
should
Oz pronunciation,as close as I can get in written form.
Salmon-----------Sam-on
In the next four,"al" sounds like "ar" as in "dark").
calm--------------karm
palm--------------parm
half---------------harf
calf---------------karf
In the next three,"al" sounds like "or" as in "bore" or "door".or "aw" in "squawk".*
chalk-------------chork
talk---------------tork
walk--------------wawk *
The next lot has the "oo" sound as in "wood",not that in "Moon"..
could-------------kood
would------------wood
should-----------shood
Note,though,there is no "u" in "solder",
And here is a weird one------"oulder" in shoulder is pronounced similarly to  the "older" in solder
Offline London Lad
« Reply #83 on: May 06, 2014, 03:03:03 pm »
What about Salmon?
calm
palm
half
calf
chalk
talk
walk
could
would
should
colonel
calm Y
palm Y
half N
calf N
chalk Y
talk Y
walk Y
could N
would N
should N
colonel N
Offline Stonent
« Reply #84 on: May 06, 2014, 03:14:26 pm »
No comments about "Leftennant"?  :-DD
calm Y (depends on how fast I say it)
palm Y (depends on how fast I say it)
half N
calf N
chalk N
talk N
walk N
could N
would N
should N
colonel N
« Last Edit: May 06, 2014, 03:16:56 pm by Stonent »
Offline nanofrog
« Reply #85 on: May 06, 2014, 03:32:15 pm »
I take it you've been listening to Stewie Griffin of "Family Guy" again?  :o  >:D
Offline miguelvp
« Reply #86 on: May 07, 2014, 12:26:33 am »
What about Salmon?
calm
palm
half
calf
chalk
talk
walk
could
would
should
colonel
East coast?
if so, how do you pronounce:
car
dad
mom
I mean even within the same country there are different pronunciations.
Offline London Lad
« Reply #87 on: May 07, 2014, 08:41:36 am »
Is 'mom' really a word ?
Offline Stonent
« Reply #88 on: May 07, 2014, 12:34:09 pm »
No I'm from everyone's favorite (or most hated) red state.
Offline vk6zgo
« Reply #89 on: May 07, 2014, 02:02:30 pm »
Ask yer Mum!
Offline echen1024
  • 15 yo Future EE
« Reply #90 on: May 08, 2014, 01:24:28 am »
TX?
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline Rigby
« Reply #91 on: May 08, 2014, 02:31:44 am »
Probably.  TX is either the best state in the union, or the worst. Doesn't seem to be a middle ground.
Offline echen1024
  • 15 yo Future EE
« Reply #92 on: May 08, 2014, 03:04:29 am »
Looking at the stupidity of some of the people around me  :palm:*10^9
Rick Perry couldn't think his way out of a wet paper bag!
Offline miguelvp
« Reply #93 on: May 08, 2014, 04:35:22 am »
I love TX my wife is from there, just because of  Perot, Bush junior,and Perry those are just people they don't represent the state... wait... hmm I guess they did and do.
Kidding aside, I love TX lived there many years!
Offline echen1024
  • 15 yo Future EE
« Reply #94 on: May 08, 2014, 04:49:55 am »
There are a lot of good, kind, smart people here. Then you go to other places.  :scared:
Offline vk6zgo
« Reply #95 on: May 08, 2014, 04:53:33 am »
North Korea? ;D
Offline jh15
« Reply #96 on: May 08, 2014, 04:57:35 am »
In New England, we don't drop the 'r's, we just re-purpose them:
car = ca
idea = ideer
deer = deea
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
« Reply #97 on: May 08, 2014, 05:10:39 am »
Just to contribute to this topic drifting further of course. I grew up with peanut paste and tomato sauce and now It is peanut butter and ketchup. I don't know if jam is jelly or biscuit is cookie. Why on Earth Aussie kids wear baseball caps (backwards or not) is a mystery.
In a global connected world it will probably merge eventually. In any case it reminded me of this episode of the British show with Stephen Fry, Absolute Power. The episode in question was Spinning America where the PR people had to make people like America and they tried to do  it by showing the people what the world might be like without the influence of American culture. It's a clever show.
This is the Episode on YT well worth a look.
No tomato paste?
Offline jh15
« Reply #98 on: May 08, 2014, 05:47:32 am »
To me tomato paste is water reduced tomatoes in a can, probably with salt. Ketchup is mostly corn syrup or sugar, with a bit of tomato and some spices.
Offline Stonent
« Reply #99 on: May 08, 2014, 06:36:44 am »
To be fair, in the US, we make a distinction between Jam, Jelly and Preserves.  Jam is the mashed fruit in Jelly.  Jelly itself is the spread formed from the juice of the fruit but is clear and has no visible fruit.  Preserves are basically Jam but the fruit is not mashed.
