Borax-laced sugar does wonders for indoor ants. And roaches.
Yeah, Borax is the only way I've ever been successful eradicating ants. I generally use the 7% Borax liquid stuff sold under many different brand names in the 100 ml bottles, (Ant-Out, Ant-B-Gon, Raid makes one, etc. all basically the same formula) but it is not available in BC anymore, outlawed by the province for some reason, (apparently indiscriminate and excessive use can attract and kill bees?)
That stuff works GREAT! Once you find a run right close to the nest, you put
JUST A FEW DROPS on a non-porous surface, whether it is a vinyl floor or a piece of waxed paper if the surface they're on is porous. I have probably a 90+% success rate eradicating colonies that way over the years. As long as you're close enough to the nest and they actually take the bait, it virtually always works. Basically if you get ants surrounding your drops and taking it all back to the nest, they'll end up feeding some to the queen, she dies. By about a week later you'll see only very small, confused, baby ants scavenging outside the nest because they're the only ones left once the queen is gone, then the nest will be toast. Generally then if it is accessible, you can physically destroy the nest at least partially so some new colony doesn't just move in.
I've never had any success with home-mixed borax, but I may give it a shot since we can't get the pre-mixed liquid here anymore. (I'll have to stock up when I get back to Calgary... My sister even tried getting some down in the US the other day and the wal-mart there didn't stock it either.)
We also have been trying the gel-based stuff which contains some octoborate something-or-other, but they're not interested in it at all. They won't touch it. I assume this stuff doesn't attract bees because it's not sugar based so doesn't attract bees? Well, it doesn't attract these particular ants, either.
My main issue, though, isn't with actually killing them, I'll figure that out, I'm sure.
My problem is I don't know where the nest is.
We had some (of what I now think were part of this same colony) take up residence over the winter in a roll of gutter screen that was in a closet. I used the last of our borax liquid in the closet and they fed on it for days. I've never seen them go on for that long. Usually an hour or two at most. My Brother was coming with kids and we didn't want the ants in there still feeding so I took the roll of screen outside and cleaned off the borax from the shelf, thinking that they
must have had enough to kill the colony, but now I'm thinking that giant blob was only part of some giant colony that is living in the roof or the walls. They're showing up all over the place now, same wierd tiny ants.
Anyway, tonight I will try a suggestion from the YouTube comments (which
I should have thought of last night... duh.) Put some sugar water out so they'll concentrate on that. Then I can see what direction they're coming from.
If they're living outside and not doing any damage to the cabin itself, I'll just try to stop them from getting in. There are probably 100 other ant colonies on the property of various types and I'm not worried about any of them.
My concern is the amount of this white dust that they leave IN the cabin, just over the course of one night. That stuff has to be coming from somewhere in the walls or ceiling. Not good. If they're infesting the walls and ceiling, they must go.
