Author Topic: Does anyone know WTF to do with PCB-containing capacitors?  (Read 9945 times)
Offline lemmegraphdat
Re: Does anyone know WTF to do with PCB-containing capacitors?
« Reply #25 on: June 18, 2013, 10:28:37 pm »
burning them is a bad idea
It's a good way to get rid of something that's pretty harmless in the first place. Drill em so the gas can escape. No go boom that way.
Start right now.
Offline c4757p
  • adieu
« Reply #26 on: June 18, 2013, 10:50:53 pm »
So... not PCBs.
Offline N2IXK
« Reply #27 on: June 18, 2013, 11:05:15 pm »
Burning them is one of the approved methods to dispose of them, but it isn't something you can do at home. You need very high temperatures and monitoring equipment to assure that the stuff isn't just going out in the smoke.
One of the main reasons that PCBs were used is that they are non-flammable, so you need a LOT of heat to destroy them completely.
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline ftransform
« Reply #28 on: June 18, 2013, 11:29:26 pm »
Yes if you don't burn then properly you can vaporize them, and cause worse compounds such as dioxins and furanes to form.
I would not attempt it lest you cause some return of the living dead shit to happen.
« Last Edit: June 18, 2013, 11:32:22 pm by ftransform »
Offline GKTopic starter
« Reply #29 on: June 18, 2013, 11:39:55 pm »
Rather than trying to put a match to it the hillbillies up north break the stuff down by zapping it with a plasma-arc.
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
Offline ftransform
« Reply #30 on: June 19, 2013, 12:02:54 am »
in some kind of special jig?
Offline calmtron
« Reply #31 on: June 19, 2013, 05:54:39 am »
I would imagine that they are using PLASCON, since it's Aussie tech and all. Neat!
The following users thanked this post: sean0118
« Reply #32 on: June 22, 2013, 05:05:41 pm »
The work ones have already been shipped off to Queensland, to be recycled by hillbillies.
So I have a "Notifiable Quantity" of PCB in my shed! When I rang the EPA they had NFI what I was talking about.  ::)
Next time find an ex wife, they take everything.
Start right now.
« Reply #33 on: June 22, 2013, 05:11:58 pm »
Maybe nade em with some 100w light bulbs, those things scare the hell out of some people, might work on the dead also.
Start right now.
